  • Replies 50
Yeh S14 are faster, but damn those things must be the ugliest model, unlike R32's, what they lose in speed they make up for in looks. They have a nice speed - looks ratio so they win overall.. for example a S1 R33 gts-t would lose in a 1/4 as well, but they're fugly and weigh more than a truck, they have a bad speed - looks ratio. Same with all magna's camry's and other cars that are identical to S1 R33's.
Basically the R32 wins overall so u still win assuming u were voting against the s14
Well based on this:
http://homepage.powerup.com.au/~slunk/400m.pdf
and this:
http://www.importdriver.com.au/Coupe_Targa.htm
Both r32gts and s14 run 15second 1/4 mile.
BUT keep in mind these are like cars out of factory in good condition.. over so many years compression drops blah blah blah..
i'll take a r32 over s14 for looks BUT S14a (series2) > r32 any day of the week.
my 2cents
i drove my mates s14 series 2 turbo stock nothing done to it and to put it simply it was the slowest sports car that i had ever driven, my golf mk4 gti is faster
but stock they are both slow the s14 and the r32
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
