Im Disgusted!
Hey all just thought id share my little experience with you....
To cut a long story short, got a workshop (supposedly a good one) to install a 33 gtr pump in my 33 gtst
I wasnt happy with the amount of racket it was making so i got a walbro one to put in myself
when i opened it up i was amazed at how shit the work was and also unsafe!
Picture 1 and 2: Both positive and negative wires insulation were ripped
and
Picture 3: The rubber seal had also been damaged
Picture 4: Cap was bashed off with a screwdriver or something that would damage it (cant u see its plastic so u shouldnt use metal!)
and last but not least they did not mount it on any sort of rubber just cable tied it to the cradle THATS WHY IT WAS SO f**kING NOISY!
sorry no pic for that.
/end of rant
If anyone wants to know the name of the workshop, pm me and i will tell you
  • Replies 42
There is usually a marco mode on the point and shoot cameras that help you take close ups, looks like a little flower on my camera, try that next time :)
Hence why I installed my pump myself....just curious did they manage to fit it so you didn't run out of fuel at half-tank as well? That seems to be a favourite.
poor bloke... no wonder i hear so many people say "no mudaf*ka is touchin my car except ME"
after seeing this i completely understand... you should confront them about it and say wtf is this shit.?
my fuel pump was installed in a similiar manner.. but in addition to the above problems, they also neglected to put the fuel pump in the bracket, or put the sock back on the bottom of the hose.... ALSO.. part of the hose towards the top had disintergrated in the fuel tank leaving floating little white bits throughout my fuel! :D
$20 says it was the same place! PM SENT!
may I suggest you use the macro-focus mode on your camera next time..does wonders for close-ups
but anyhow.. dodgy-brothers! as they say, if you can do better, may as well do it yourself!
Should have a petrol resistant foam rubber sleeve and hose clamp/s to mount it. I've not seen ANY shop including autosparkies that wire things up neat. Kindergarten kids could usually do better!!
They usually use the biggest soldering iron they can find, two rolls of dodgey insulation tape per job, have five twist joins in a 500mm length of wire, and crimp all connectors with a hammer or sidecutters.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
