  • Replies 42
Should have a petrol resistant foam rubber sleeve and hose clamp/s to mount it. I've not seen ANY shop including autosparkies that wire things up neat. Kindergarten kids could usually do better!!
They usually use the biggest soldering iron they can find, two rolls of dodgey insulation tape per job, have five twist joins in a 500mm length of wire, and crimp all connectors with a hammer or sidecutters.
LOL f*kn hacks!
What they figure is... if you don't see it.. it wont hurt you...
WRONG MUDAf*kRS!!!
They should take a crash course in how to unf**kthemselves.
OK OK, XXX did it. I spose its not bad to say it because i am sharing information that could be useful, as someone said if they cant see it it wont hurt them (the customer) or something along those lines. thats why i was so eager to get back in the tank and see what they really done.
First and last time to go there, wasnt happy with the service from the start.... i made an appointment at 10am and didnt leave until about 2.45.... but i spose workshops can be like that
i payed $120 for the install only... the pump was supplied by myself.
mods if u think this thread is not within guidelines than feel free to edit.
on a good note i got my FMIC installed today, happy with that and the guy who installed it
**edited by mods - please don't mention names**
I have a similar problem last workshop I left my car to gave me the car with
1 dint in the front passenger panel..denied by them.
1 window seal badly notched "drivers side"
1 side skirt chipped"drivers side"
I need to install cams/afms and retune.
I am not giving it back to these guys.
There work was good but are rough as guts on your car.
PM ME IF YOU WANT TO KNOW WHO THEY ARE IN MELBOURNE.
Probably best course of action if it hasnt been too long would be to sit down and consult with them, and maybe work out some appropriate resolution. but then again its upto how you would proceed in this circumstance. There are many and many dodgey work places, and very few that actually know what the hell they are doing with our cars and even less that will take the time, effort and care with out cars on anything mechanical. Hence why so many people do things themselves. Well one of the many things why anyway.
Noo good even still atleast you got to it sooner than later
it has been over a month since i done it, for the matter of 120 dollars i cant be bothered going back especially since they cant see it while it was installed. they will most porbably make excuses etc etc and highly doubt i will get my money back and i dont think there is anything else they can do for me.. i will just not go back there again
how much diff is the GTR pump over the stock? i would think the GTR would be easier to install than a walbro (aftermarket), I would think the GTR would use the stock mounting brackets etc. pm me the reply with the name of the workshop too. please thanks :)
walbro comes in a kit form and is so easy to install, it has a new hose with clamps, rubber mount down the bottom and pickup filter thing. also has a wiring harness with it. The hardest part is cutting the + and - and crimping/soldering them to the new harness LOL.
GTR pump uses everything the same so u dont need new hoses etc but it is slightly different on the bottom and wont sit in the cradle with the GTST rubber mount so this is where it gets ugly. If u a suitable piece of rubber and half a brain u could make a similar mount but yeah it help to have everything there when ur tank is opened up and u have no car to get bits and pieces lol
  • 5 months later...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
