If it is a real accident... there is no way they've removed any bodies from that chassis yet. =-o
Disturbing!
The Top Gear test-crash of a Smart Car came out much better than this... from 70mph into a concrete barrier, and you'd still be in one (injured) piece.
https://www.sau.com.au/forums/topic/158692-new-compact-car/#findComment-2950994
Disturbing!
100km an hour carx(head on)100km an hour truck=200km an hour brick wall.
I think this is how it goes.May they rest in peace
https://www.sau.com.au/forums/topic/158692-new-compact-car/#findComment-2951244
looks like the truck was the one in the wrong lane too
Take another look at the pics & you might just see that it was indeed THE CAR that was on the wrong side of the road (LHD NOT RHD vehicles)
Don't automatically conclude the truck driver is at fault or you're no better than the people who take great satisfaction in categorizing us all as "hoons" simply thru our choice of vehicle. Also rather than simply an accident I'd almost go as far as to say this looks like "suicide by truck". Too square a hit to be an accident, esp as you can see the truck has made an effort to avoid the impact.
https://www.sau.com.au/forums/topic/158692-new-compact-car/#findComment-2982436
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
