There's a few here in SA that have basically just been bolted on.
It appears ~20psi makes a shade over 300rwkw.
I'd assume the difference between 20psi making 340-380rwkw and 20psi making a shade over 300rwkw is nice exhaust manifolds, plenums and a decent set of cams.
yeah. thats what i rekon to. im making atm 307 awkw on a t04z on 20 pound.
to be honest id expect more. but a stock as a rock motor just with the nesasery suport mods. im guessing yeah cams etc etc.
A LOT of people with the usual gear are getting 370-420rwkw on PULP without even going to Meth :P
Thats just the usual mods and around 23-25psi or there abouts.
I reckon you have a good number of things to look at if a t04z is only making 300rwkw on 20psi. Its a good 50-70rwkw down on what it should be
I run the 0.81 AR T04Z with a built 2.7 engine, cams, 4in exhaust, HKS manifold and i make 450kw on 24psi, thats nearly 1.8 bar. and BTW how does the stocker engine respond to a monster turbo like the T04Z. and how do you keep the old girl alive, dont you have issues with blowby due to older piston rings??
if i hijack this topic my apoligies
well morgs and pretty much everyone else has cams at the least. and a built motor with forgies so abit of timing could help.
my motor is still going strong. 170pound across all 6. (apart fron some cool oil leaks lol.
i put it down to oil and oil temp. and a concervative tune. tuners get a litle scared when they find out its a 230k old donk hehe.
so penrite syn 5 or syn 10. two 25 row oil coolers and overfilled oil by 1 litre. (up to the hump on the stick) to stop oil surge.
I must say is there much variance between the garret and hks versions in overall powerout put nismoid
Not to the tune of 70rwkw i dont believe so.
A few GTR's have been using Garrett t04z's here for a while and those are what im going off.
Not the HKS versions
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
