Hi all, I would like some advice.
I have jacked my car up off the ground and found that I can wobble my rear wheel about 5mm by applying fairly slight pressure with my hands on the left and right hand side of the wheel. It does not wobble when I shake it from the top and bottom. Is this normal? Have I got worn bushes? Tyre wear seems normal.
My car is a 1993 R32 GTS4 with stock arms / bushes, GTRGeoff hicas lock bar and whiteline shocks.
I have put a (dodgy) pic of what I mean to help with my explaination.
Thanks,
Ben.
sounds like a worn bussh somehere. Go to pedders and get a $14 28 point safety check, that is the best way to pick up problems. After that you can do all the work yourself.
There are a few bushes there, so maybe take the wheel off and have a good look arround. Maybe a ball joint on the lock out bar.
combination of old soft rubber bushes front and a flogged out tierod ball joint (or tierod end) rear.
If you remove the rubber boot on the end of the hicas rack and get someone to move the wheel for you it's pretty obvious if the ball joint is shagged. Any movement = borked
it will be combination of the link bushes and the tierods, more likely the tierods. Did you fit the old steering arms to the hicas lock bar?
The rear bushes needs a little movement in them because the hicas is basically compressing the bushes to give the car rear steering.
But you should not feel any movement at all by hand.
First thing I would try is new steering arms (from the hicas lock bar to the tierod end in the hub) as the ball joint might be worn. If that doesn't cure it then you will need to remove the hubs to replace the link bushes in the hubs. Once you see how involved that is you might as well replace the lot, because its not a job you want to do twice!
I replaced the bushes in my hubs, and the steering arms and that tightened up the rear end so that you couldn't feel any movement at all. The next step would have been to replace the bushes in the links themselves to have basically new rear suspension.
The car felt more controlled at high speed into corners after that (on qld raceway), and I think that the Hicas was not in any way detrimental to the cars handling considering that the hicas was now working with components in good condition.
  • 10 months later...
When removing the rear hub assembly did you have to replace many parts
was wondering if i can just unbolt the shafts and the hub assemblys etc
replace tierod /hicas ends in a press then bolt it all back up?
I assume you would have to use a press or maybe a porta power to actually press the tierod /hicas ens out of the hub assembly etc
  • 5 months later...
sorry mate what are s/h items...my car has done 125000kms...but the guy before me had shopped springs in it..so that would have sped up the wearing out process...
also what do they cost and from where?
s/h = second hand.
chopped springs would be unlike to cause damage. Hitting gutters ripple strips etc would. :)
I picked up a complete rack from Wally at Zimports for bugger all can't remember the price but it was under $100.
I recently bought a new steer rack with rod ends as the front left did the same; that cost me $100 for the complete rack and tie rods.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
