Greetings,
Hi guys..i'm Jai from Malaysia..
i've a few questions and opinions to ask you guys..
i have a 1984 Nissan Bluebird 910..(it's not a skyline..but it's classic.. :D )..just finished bodyworks and full chassis strengthening...this car will be used 100% for drifting purposes only..
now i'm deciding on what engine should i put in it...either SR20det, RB20det or RB25det...
at first i want to use SR20det..but here in my country spare parts and upgrade parts for sr20 are more expensive than RB parts...furthermore...i read a lot that sr20 motor is not as tough as rb motors...especially the valve train components...so..it's very unfortunate that if i want to built more power safely, i need to put a lot of money to upgrade it's reliabiltiy and durability i.e. stiffer valve springs, rocker arm stopper kit, sping retainers, trust oil pan and etc..
RB20det conversion in a 910 is very common here in my country coz it's the cheapest solution..a lot of RB users here are afraid to use sr20 bcoz of the above mentioned factors...as far as i know..there's very few people install RB25det in a 910 coz it's a bit more expensive than Rb20det..
i've tested a rb25det cefiro and i feel that the pulling torque and response is phenomenal!! i believe it's greater than sr20det..
if i install RB25det...will i totally mess up the balance of my 910 for drifting? if anybody know..what's the weight of Rb20det and Rb25det?
i feel that Rb20det's torque comes a bit later in the RPM range...if i use this engine..how can i increase the response and make the torque comes earlier? (like Rb25det and sr20det)
i have no budget constraint if it's a RB coz i know the motor is tougher, reliable & more robust than SR, so guys...what do you guys think? for drifting...should i go for Rb20det or RB25det straight away?
Really appreaciate your advices and recommendations..Thanks :D
https://www.sau.com.au/forums/topic/158738-sr20detrb20det-or-rb25det-in-my-910/
rb20........ great bang for buck....and in a light car... pull insanly hard.... ( i should know, ive done it in my lil gt)
140KW @ the treads and it only ways like 1000kg.....
:nyaanyaa:
Edited by 66 skyline gt
If you have them there I would consider a KA24DE , belt drive DOHC 16V engine and no rockers like SR20's have . They are a long stroke engine but being a four much shorter than an RB 6 . Bluebirds are a problem with long engines esp FJ20's where they have two staggered twin row timing chains AND a water pump on the timing cover in front of those . These cars fight you all the way with fitting adequate cooling and intercooling systems but it can be done - been there .
As per the 2.4 litres , they make more torque at pedestrian revs than FJ20's/RB20's so you can fit turbos that work well with the combination . In the US they play lots with turboed KA24DE's and there is lots of parts available for them . Here in Aus we get the KA24DE in a comercial vehicle and std it has 8.6CR pistons so has potential unopened . Search Jim Wolf Technology and the US sites who cover the S13 and S14 240SX cars , the S14 had the KA24DE in RWD form .
Cheers A .
he're in Malaysia we don't have KAs..hehe...i'm sure the torque of a KA is phenomenal considering the length of the stroke..
how about between these two..RB25 and SR20 for drifting...what do you recommend...?
go the SR20. Lighter than the RB, has a punchy power curve with a slightly larger turbo, and easier to fit your application
yeah I would go either the RB25 or the SR20. the 20 is a great motor, and light and torquey, but if you have trouble with support and parts in your country then it's probably not a good choice. The 25 will be nice and torquey, and is not much (at all?) heavier than a RB20 so I would go the RB25 in your case.
i'd go the SR, if you want it for drifting then thats the go and if the balance of the car is better with the SR then thats another plus.
from what i know drifting seems to be more revs and car balance more than low down torque, mate up a desent turbo and you'll be fine...
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
