Greetings,
Hi guys..i'm Jai from Malaysia..
i've a few questions and opinions to ask you guys..
i have a 1984 Nissan Bluebird 910..(it's not a skyline..but it's classic.. :D )..just finished bodyworks and full chassis strengthening...this car will be used 100% for drifting purposes only..
now i'm deciding on what engine should i put in it...either SR20det, RB20det or RB25det...
at first i want to use SR20det..but here in my country spare parts and upgrade parts for sr20 are more expensive than RB parts...furthermore...i read a lot that sr20 motor is not as tough as rb motors...especially the valve train components...so..it's very unfortunate that if i want to built more power safely, i need to put a lot of money to upgrade it's reliabiltiy and durability i.e. stiffer valve springs, rocker arm stopper kit, sping retainers, trust oil pan and etc..
RB20det conversion in a 910 is very common here in my country coz it's the cheapest solution..a lot of RB users here are afraid to use sr20 bcoz of the above mentioned factors...as far as i know..there's very few people install RB25det in a 910 coz it's a bit more expensive than Rb20det..
i've tested a rb25det cefiro and i feel that the pulling torque and response is phenomenal!! i believe it's greater than sr20det..
if i install RB25det...will i totally mess up the balance of my 910 for drifting? if anybody know..what's the weight of Rb20det and Rb25det?
i feel that Rb20det's torque comes a bit later in the RPM range...if i use this engine..how can i increase the response and make the torque comes earlier? (like Rb25det and sr20det)
i have no budget constraint if it's a RB coz i know the motor is tougher, reliable & more robust than SR, so guys...what do you guys think? for drifting...should i go for Rb20det or RB25det straight away?
Really appreaciate your advices and recommendations..Thanks :D
https://www.sau.com.au/forums/topic/158738-sr20detrb20det-or-rb25det-in-my-910/
rb20........ great bang for buck....and in a light car... pull insanly hard.... ( i should know, ive done it in my lil gt)
140KW @ the treads and it only ways like 1000kg.....
:nyaanyaa:
Edited by 66 skyline gt
If you have them there I would consider a KA24DE , belt drive DOHC 16V engine and no rockers like SR20's have . They are a long stroke engine but being a four much shorter than an RB 6 . Bluebirds are a problem with long engines esp FJ20's where they have two staggered twin row timing chains AND a water pump on the timing cover in front of those . These cars fight you all the way with fitting adequate cooling and intercooling systems but it can be done - been there .
As per the 2.4 litres , they make more torque at pedestrian revs than FJ20's/RB20's so you can fit turbos that work well with the combination . In the US they play lots with turboed KA24DE's and there is lots of parts available for them . Here in Aus we get the KA24DE in a comercial vehicle and std it has 8.6CR pistons so has potential unopened . Search Jim Wolf Technology and the US sites who cover the S13 and S14 240SX cars , the S14 had the KA24DE in RWD form .
Cheers A .
he're in Malaysia we don't have KAs..hehe...i'm sure the torque of a KA is phenomenal considering the length of the stroke..
how about between these two..RB25 and SR20 for drifting...what do you recommend...?
go the SR20. Lighter than the RB, has a punchy power curve with a slightly larger turbo, and easier to fit your application
yeah I would go either the RB25 or the SR20. the 20 is a great motor, and light and torquey, but if you have trouble with support and parts in your country then it's probably not a good choice. The 25 will be nice and torquey, and is not much (at all?) heavier than a RB20 so I would go the RB25 in your case.
i'd go the SR, if you want it for drifting then thats the go and if the balance of the car is better with the SR then thats another plus.
from what i know drifting seems to be more revs and car balance more than low down torque, mate up a desent turbo and you'll be fine...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
