Hi,
i know alot of people here have set high prices for there gtrs & its fair enough its there pride & joy and want top dollar for it or even close to how much they paid for it but if your on a budget makes it kinda hard to find one..
i was told 6months ago an importer of a friend could of got me one for 16,500k n i thought he was full of it considering the prices people have them for on carsales etc & due to circumstances no longer have that contact
so basicually what im looking for is a ruff indication on what are they going for in japan so i can get one landed & complied.
who would be the best to talk about getting one from japan if thats the cheaper option & what am i looking at price wise?
cheers.
https://www.sau.com.au/forums/topic/158762-what-am-i-looking-at-for-an-r32-gtr/
A lot of guys have gambled on a $15k GTR & most have bought hand-grenades with shorter-than-acceptable fuses. To me any decent R32 GTR is a $30k proposition & yeah I know the prices have been dropping lately, but you really do get what you pay for & that is still as relevant as it was 12mths ago.
If you go into the deal with a budget of $25-$30k you stand a very good chance of getting yourself a nice car. You can either buy a good one straight-up or gamble on nothing going wrong with a cheapie BUT if you only have $15k to spend all up, when not if something goes wrong you'll be stuck with a car you can't use. If it doesn't, you're ahead but is it really worth the gamble??
Also do not under any circumstances scrimp on insurance, there are waaaay too many stories of "I didn't get insurance 'cos...." that have ended in tears. Don't be another one.
Good Luck
$25K will buy you a 32 GTR worth owning. to be honest I wouldn't worry about how much it costs. if you want to have fun with it you will find over the first 2 years of ownership you will easily spend the purchase price again on the car.
You may aswell cut your throat if your going to try get a "cheep" gtr
i'd say a nice example in japan now would be around 1.5mil
Now do they have to be standard for compliance?? as there isnt a 15 yr rule?
Edited by Angus Smart
It cost's 1.5 plus for a GTR worth importing/owning unless you only want one for less then 12 months as you worked out you cant afford to own a "cheap GTR" they are expensive to own and getting a tired one isn't a good start.
It took me months to find my test car and condition was all I cared about not budget, year, spec, colour or klm, we are talking about a 12 to 16 year old highly tuned car.
Spend $12,000 to $15,000 on a GTS-t then you will be able to modify it and keep it running.
mine just popped up out of the blue! and the price was hard to refuse! bye bye gti-r helllo gtr. very good conditon circuit thrashed monster i fell inlove!
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
