Quick question for the more technically inclined:
I'm putting a HKS2535 onto my rb20 tomorrow...I know that ball bearing turbos usually require a restrictor in the oil feed...my question is since the the stock turbo on the rb20/25 is ball bearing anyway...will i still need an oil feed restrictor?
I'm using a braided line that came with the turbo and I'm unsure of what the internal diameter of that line should be...would the standard holes in the banjo bolts be enough to restrict the oil flow for the new turbo?
Cheers...
https://www.sau.com.au/forums/topic/158764-another-oil-feedrestrictor-question/
Cheers...
The oil flow restrictor is in the inlet fitting in the turbo core.
Supply pipework size is irrelevant, ie; the restrictor is smaller than the smallest pipework you could buy.
:O Cheers :woot:
:( Cheers :)
SK is this the same for the garrett GT series turbochargers? I assume so. ALso in regards to the inlet line, I was thinking it ocould be a good idea to make it curl like the factory does IIRC, or would that restrict the flow of the oil and starve the turbo then? (I think Nismoid did this on his RB25)
cheers
-Jez
cheers
-Jez
The oil is under pressure, you can't restrict the flow pigtailing it. You can only stop/restrict the flow if you kink it. If you use braided line there is no need to pigtail it, the pigtail is only there to allow some flexibility [given that it is a hard pipe ie steel and inflexible] for vibration between the block and the turbo. A braided line is already flexible so caters for this.
I would avoid having the hose to short - a tight fit, but I would also avoid having the hose too long, allowing it to flop around and wear on other parts. I would think that if it was around 50mm longer than a straight line fit it would be ideal.
Excuse my dumbness, WTF is -3 hose? And it still doesnt answer my question, does the garrett have a restrictre built in? :P
3mm ID
If its a late model [modern] unit ball bearing then yes it should
GCG supplied me with a restrictor that pushed into my -4 line where it screws into the block.
but the hole in it was only about 1mm.
i would check with them if i was you. tell them the no. on your turbo and they will tell you if you need one or not.
the restrictor looks similar to a head oil feed restrictor.
to me 3mm sounds like you dont have a retrictor at all.
But its supposed to be in the turbo? Not the block?
Does this mean you can't see it? I've got my GT3076 in my hand and the only restriction I see is the 3mm hole/seat that the banjo bolt tightens into/onto. I don't see any other smaller hole.
The bolt shown above would not work, the brass insert would be sitting on the seat, not ver it.
Not sure how applicable it is to the RB's.
GCG appear to believe it is?
http://www.turbobygarrett.com/turbobygarre...r/faqs.html#t16
Ball-bearing turbochargers can benefit from the addition of an oil restrictor, as most engines deliver more pressure than a ball bearing turbo requires. The benefit is seen in improved boost response due to less windage of oil in the bearing. In addition, lower oil flow further reduces the risk of oil leakage compared to journal-bearing turbochargers. Oil pressure entering a ball-bearing turbocharger needs to be between 40 psi and 45 psi at the maximum engine operating speed. For many common passenger vehicle engines, this generally translates into a restrictor with a minimum of 0.040" diameter orifice upstream of the oil inlet on the turbocharger center section. Again, it is imperative that the restrictor be sized according to the oil pressure characteristics of the engine to which the turbo is attached. Always verify that the appropriate oil pressure is reaching the turbo.
The use of an oil restrictor can (but not always) help ensure that you have the proper oil flow/pressure entering the turbocharger, as well as extract the maximum performance.
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
