hey ppl i can build pleniums and do some cooler pipes made from whatever you want stainless ,mild,alluminium, ill put a couple of pics up soon cheers russ ph 0409027723
You kept that under your lid cobber. You should of posted this up in the Tassie section as well you would be run off your feet :O
looks good...where are you based?
Russ has double the brain power :)
https://www.sau.com.au/forums/topic/158783-plenum/#findComment-2948904
imm in hobart and will make it to whatever specs you want ,currently makeing one that looks like a gtr one for a rb20det ,can make strut braces,cooler pipes, mandrell bent exhausts,diff rebuilds ,diff conversions,5 stud conversions,big brake upgrades,turbo rebuilds,turbo hiflowing,just about anything rearly just ask if i carnt build it ill know someone who can
https://www.sau.com.au/forums/topic/158783-plenum/#findComment-2953339
how much for a jun style plenum for r33 rb25det? PM Me!
https://www.sau.com.au/forums/topic/158783-plenum/#findComment-2966853
excessive?? he's prob got close to 250rwkw... shouldn't that be ok?? nice work btw mate...
yep my rb20det makes 208rwkw @18psi plenum is only 3'' thick bolted to the orignal lower runners.currently makeing one that is like a gtr one will post pics when finished .all plenums have bellmouthed runners on the inside to improve flow and stop leaning out in the rear 2 cylinders
if you send me a pic of the jun stile ill have a look and get back to you cheers russ
Edited by 31r
https://www.sau.com.au/forums/topic/158783-plenum/#findComment-2994598
  • 1 month later...
  • 2 months later...
  • 2 months later...
    • Brakes definitely won't make him faster. They only slow you down. 😛
    • cool car to be working on, but I think you need some really old school help on this one
    • Hey, I understand this is a skyline forum but I was hoping someone might be able to help me out here. Got an ‘84 M10 Prairie with an E15S that I’m trying to get running again after replacing a head gasket. I’m having some struggles with vacuum lines after replacing a couple perished ones. They’re all set up like in the diagram I’ve attached. I’ve tried starting the motor and my carb backfires a bit but no luck getting it to run.      Theres a 2nd port on the back of the carb that isn’t mentioned in the diagrams, right next to what I believe would be the idle screw (sorry I’m no good with carbs) - should this be attached to any lines?   any help would be greatly appreciated, I’m sick of pulling my hair out trying to figure this thing out 🤝🏼
    • If the current relationship is between the diff and the speedo, then no, you will not need a speed sensor in that hole in the gearbox. If the car were an R33 GTST, or an R34 GT-T, then it would need a speed sensor in there. Because that's what those cars have/need. If the car were an R32, then it will need a cable drive cobbled together from a Navara speedo drive, because R32s can't handle an electronic speed signal to the speedo.
    • Just to follow up on this.  Will the speedo work with this? Like to have plugged speed sensor on this trans and still using one on diff from N/A (open) diff?
