hey ppl i can build pleniums and do some cooler pipes made from whatever you want stainless ,mild,alluminium, ill put a couple of pics up soon cheers russ ph 0409027723
You kept that under your lid cobber. You should of posted this up in the Tassie section as well you would be run off your feet :O
looks good...where are you based?
Russ has double the brain power :)
https://www.sau.com.au/forums/topic/158783-plenum/#findComment-2948904
imm in hobart and will make it to whatever specs you want ,currently makeing one that looks like a gtr one for a rb20det ,can make strut braces,cooler pipes, mandrell bent exhausts,diff rebuilds ,diff conversions,5 stud conversions,big brake upgrades,turbo rebuilds,turbo hiflowing,just about anything rearly just ask if i carnt build it ill know someone who can
https://www.sau.com.au/forums/topic/158783-plenum/#findComment-2953339
how much for a jun style plenum for r33 rb25det? PM Me!
https://www.sau.com.au/forums/topic/158783-plenum/#findComment-2966853
excessive?? he's prob got close to 250rwkw... shouldn't that be ok?? nice work btw mate...
yep my rb20det makes 208rwkw @18psi plenum is only 3'' thick bolted to the orignal lower runners.currently makeing one that is like a gtr one will post pics when finished .all plenums have bellmouthed runners on the inside to improve flow and stop leaning out in the rear 2 cylinders
if you send me a pic of the jun stile ill have a look and get back to you cheers russ
Edited by 31r
https://www.sau.com.au/forums/topic/158783-plenum/#findComment-2994598
  • 1 month later...
  • 2 months later...
  • 2 months later...
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
