  • Replies 407
Posted Images
well done lowndes. top drive.
shame about skaife. the safety car timing was all wrong for him today and it seems he overcooked it a bit at the end. :)
seton finished in 11th and was looking pretty handy towards the end. nice one seto.
2006 car 888 start 6th finish 1st
2007 car 888 start 6th finish 1st
Coincidence i dont think so!
I am saying right here and now that Lowndes will be the next king of the mountain, i woundnt be surprised if he out does Petes record. i honestly believe thate pete is up there smiling down on him just look at the 2 near misses he had with cars nearly T boning him. Its cosmic i tells ya
can anyone tell me why it was safe to drive past mcconvilles car on the first lap, on cold tyres and with drivers not knowing where it was - but it is not safe to do a second lap with warm tyres and the drivers knowing where the stopped car was.
typical commercial considerations coming before safety again
Bit of a tough call either way in that case. If they recovered the car before starting the race, then the cars would have to do another warm-up lap and line up on the grid again. This all takes time and would have delayed the start by a number of minutes. Neither the spectators nor the drivers want this delay. Having them start and then circulating under the safety car is a prefferable option as the agro has died down a little and drivers are getting more into the rythm of things.
Great race, great work by the boys that finished 1, 2, 3. I wanted to see Lowdnesy to do the back-to-back, but I also wanted Stevie to win, good for getting outta old man Dick's shadow..
Big showing by Ford and Queenslanders. Just had to go out for a lap in the BA XR8 Ute.
Well actually I was sent to get dinner :)
I was seriously impressed with Juniors' drive. Here is a man that perhaps doesn't ooze natural talent but damn he works hard and finally a worthy result.
So 4 rounds left? I wonder if Garth will be doing any blocking for the 90lb weakling this year, or give it a punt for himself?
Not a bad race on the whole. The start was shocking, WTF were race control thinking. If there was an accident with the supercheap car i'm sure it would have either taken out half the grid or ended with a possible legal fight due to the noticeable danger (just look at the incar from 888)
Would have been good to see JNR up a few steps on the podium. He and will drove a very consistent race - clean pits stops and were lurking every time the other 2 fell off or stuffed up their pit strategy.
Toll was a huge surprise the same problem in 2 of the 4 TWR cars and teh team mates!!
Brighty had everything to loose when he came in for his last pit stop and he did loose everything.... its a shame as it would have been a huge upset if he put wets on and built up a lead in the wet conditions (not to mention i had my britek shirt on :) ).
yep when it shook out with bright in the lead I was gunning for him. he certainly deserves a drink. he probably should have just stayed on the tyres he had, or gone to wets. brand new slicks didn't seem to be the best choice. but it's easy to be an armchair race engineer.
Sorry Ben,,,but no amount of edittings gonna help ya mate. Pick a date my good man and charge up those cameras batteries.
Poor bloody frosty it was his for the taking and poof its all over.
So who's booking there car in with Toll racing for there next brake job?.
Neil.
Would you like air in your system for no extra charge?.
oops... must have skimmed over the "Toll Racing" bit. definitely a NO.
Was amazing to see all the teams change pads and rotors so quickly though. Insert prongs here, take out pads there, shimmy the rotor in here, give it a good whack and away you go.
I thought it was a great race, and an awesome last 20 laps! I was on the edge of my seat.
I was hoping Bright would go to wets and make it stick, but no such luck. Definately looked like a hairy ride for him, especially with most of the field sitting on his bumper.
Well done to Lowndes, he drove well. Pity Murph and Jimmy didn't get up there, but those that got on the podium deserved it.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
