Reluctant sale :no:
R33 gtst series 2 Sedan 2.5 t manual m spec
specs
Sparkling Pearl white a/m paint job
18 " ava wheels
119 000 k's
2 1/2 cat back exaust into twin cannon muffler
nismo 300k dash cluster
gfb hybrid bov
k & n filter insert
a/m locked diff
Alpine stereo components through out ( selling optional )
33SUM nuber plates white on black ( selling optional )
safety cert
Very reluctant sale but it's time to move on. car has been with me for bout 2 years and maintaned it
very well, always garaged and kept tidy. it is in a 1 condition and is great alternative to a 2 door and much more rare. car is very fast and sticks well on launches with the diff and is great round bends due to good tires all round 99% front and 90% rear. car was a grade 4 import and has been rarely driven since buying as i have a company car and would only drive it for leasure. reason for sale is that recently had a baby and need do get a family car.
stereo
alpine flip face head unit
type r front splits
types s 6" rears
type r 12" sub in box
pioneer 800w mono block amp
First to see will buy will not disappoint rare car of model and in it's condition
price $18 000 with plates and stereo. ONO
or $ 16 000 without stereo and plates. FIRM
please no time wasters
Edited by 33SUM
https://www.sau.com.au/forums/topic/158807-sold-please-delete/
why the locked diff? what was wrong with the factory LSD?
not sure mate it was on the car when it was imported along with a very aggresive clutch ( which i replaced with an exedy h/d number ) i think it was a project car but they must have decided to sell instead.. it's great fun to drive with it back there though.
I saw this car the other day at Drum Mechanics, very nice. If I can offload mine in good time I would take it. Pity about the diff though, thats more money to spend replacing it.
i'm not sure why you would want to replace the diff but each to there own i guess, as it works perfectly.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
