Hey guys,
This really isnt that bad a problem but it's doing it more and more often these days... no matter if the car is warm or cold... Ill turn the key and she'll kick over and instead of starting shooting nicely up to 1000rpm, she trickles in... hard to explain, its like theres no bounce to it. Once it passes that, she idles and drives fine.
The power FC is currently tuned to v-power racing, the 100octane ethanol stuff... Ive heard that this is more viscous than say BP ultimate and something (lines, injectors?) is getting clogged. Could this be the problem?
Thanks in advance
Andrew
https://www.sau.com.au/forums/topic/158817-weak-start/
fuel filter? Its starving for fuel till it gets going, I'd say water in the filter.
well to be honest it only started after the alarm was installed - and he MOVED my fuel filter. I'll swap it and see whats happens. Thanks heaps
https://www.sau.com.au/forums/topic/158817-weak-start/#findComment-2948949
More of the picture------its going to be filter OR alarm related. Filter is easier to check for now.
https://www.sau.com.au/forums/topic/158817-weak-start/#findComment-2949525
I read somwhere, that common cause of starting problems is due to the engine being cold. Metal expands when its cold and this causes the compression in pistons to have leaks hence the poor idling?
Seeing as R32 is an old engine, it would be worn and be more prone to leaking etc etc.
Not sure how valid this theory is haha.
https://www.sau.com.au/forums/topic/158817-weak-start/#findComment-2950482
Wherever you read it has their facts and physics wrong
Nothing expands when its cold, it shrinks
Things expand when they're hot
https://www.sau.com.au/forums/topic/158817-weak-start/#findComment-2950883
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
