This is one awesome, fast, hassle free car!
Make: Nissan
Model: R33 Skyline GTR V-Spec
Year: 1995
Km's: 124,xxx
Engine: 2.6ltr Twin Turbo
Gearbox: 5SPD Manual
Modifications: Apexi Pods, 3.5 inch cat back exhaust
Interior: Excellent Condition
Stereo: Kenwood Double Din CD\Tape\Radio, splits in front, 6x9's rear parcel shelf, New 12" Sony Sub and amp
Exterior: White
Driveline: AWD
Wheels & Tyres: 18" mag wheels
Extra Details: 8 months rego, 2+ years warranty, New Cruise Control, New Brant 3 point Car Alarm, Turbo Timer
Item Condition: Good
Location: Sydney (Can take to Brisbane / Gold Coast if serious offer)
Reason For Sale: No longer suites life style and want it to go to a good home
Contact Details: [email protected] / Call Brendan on 0414 647 333
Price and Payment Conditions: $27,400 neg.
Make me an offer!!!! Need to sell ASAP!
Edited by BrendanS
https://www.sau.com.au/forums/topic/158820-r33-gtr-v-spec-for-sale/
Is a very very nice car!
I do like it and i am in the market for a GTR. Currently after a 32GTR and have put an offer in, If he declines then i will most likely ask a hell of a lot of questions to you and if answers are all good then i will put an offer in also.
Best of luck witht he sale and car is very very very nice!
How did your offer go on that R32 Jake? Wouldn't you mauch rather an R33?
Hey,
I havnt heard back from the 32GTR owner and would have liked to but seems i must move on now.
Sadly i have had to have my Wisdom teeth removed and funds are stretched even shorter now, to the fact ath i not sure i could make an offer that wouldnt be offensive.
If it comes to the stage that your desperate for cash let me know otherwise i really wouldnt want to insult you.
I am looking at S15's at the moment but i am patient enough to know not to jump into a decision like buying a car and not being happy with it (learned the hard way)...
Thanks for the follow up though =)
Cheers Mate. Its unfortunate it has to go but i spend alot of time in the bush camping so rather than trying to get a lift with someone all the time i have decided i need to get an off road 4wd. I got it for a pretty good price and now i'm just passing on the good price for someone else to appreciate an awsome GTR.
Nice looking V-SPEC. Much better than the other R33 GTR's for sale at the moment.
Cheers Jake, You can try me on your offer but your right i can't go much lower than $27,400. But if things change besure to let me know...
Hey,
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
