Yeh the guy welded a nipple on there, its all set up correctly
it boosted to way over 1 bar so i adjusted it down (undid the bolt than allen key) than tightened the nut back up. but its just about on the last thread on the allen key bolt and it wont go lower than 0.9 bar
want to run about 11 psi which is roughly .7-.8 bar
what you can do is go down to your local spare parts shop like auto pro (which is where i got mine from) and take the spring to them. ask them for one the same size - my local auto pro had one.
cut the spring to be a little shorter and use that spring. also on the side of the spring that sits on the little ball - bend the last curl in a little bit so that the ball cannot crawl inside the spring or it will do some crazy stuff (run less boost not more so its safe)
make sure its all correct and see how it goes
it must be the setup - since you changed the cooler its running more boost on the stock actuator.
Try taking the spring and the ball bearing out and then testing how much boost it runs (put the screw in 2 turns and lock it in just to seal it off) and that will give you a indication on the minimum boost you can run.
If you do that and it runs the boost you want then leave it like that untill you plan to turn the boost back up again.
These are great controllers.. i run one on my rb30det with 317 rwkw with external gate, the boost curve is straight as.. so yeah try that and see what it does then let me know.
Edited by Guilt-Toy
the problem is that the turbotech boost controllers are very sensitive.. as in very small turns of the screw change the boost in big ways. mine is almost screwed out completely to hold 14psi
that and adding a FMIC changes the overall restriction in the intake. you will ifnd that there is less restriction there now and this is affecting your boost reading. just re-adjust it and you'll be fine.
cheers,
Warren
i went looking for a spring and couldnt find one the same size at bunnings or autopro cbf looking anymore.
From my understanding, when u UNSCREW the bolt... the boost goes down. when u SCREW it in, it goes up
and if this is so i cant get less than 0.9bar before the screw falls out
has anyone with a 33 and fmic run 10psi with this boost controller or minimum is about 14 which is all i can get?
Well this is my Experience with it.. yeh...
When i 1st got it.. i installed it and the Boost would spike up and go over 1 bar. No Matter what i did i couldn't control the Boost level n will keep goin over 1 bar.
Then soon Later after i got my FMIC installed.. i tried using the TurboTech again n see how it goes. It started working the way it should do.. got it to run to about 10 to 11 PSI.. but it was screwed all the way in, I couldn't run higher boost after that.
Worked out well...
And now when i have the Bolt all the way in or out it would read the same boost level... 10-11 Psi..
I dunno Y.. maybe it's the way it's been setup.....
What do u reckon guyz????
-SeSaR
I thaught when you tighten a bleed valve it actually decreases the boost your turbo makes because its not bleeding air off, which then in effect should give you the boost that its meant to make normally like 8psi or sumfin with your mods...
If you unscrew it, it bleeds air off not letting your actuator open all the way causing your turbo to make more boost... make sure its pointing the right direction aswell dude... like i think arrow towards actuator (can't exactly remember)
But yea they're tempremental and could spike every now and again and cause fluctuation in boost pressure.. if its completely closed you should be running stock boost like 8psi...
wtf.. first you say that that un screwing it lets you run less boost then you say if you have it closed it runs less boost.. WTF ??
If you unscrew it then it will run less boost.
if the screw is falling out of the valve and it still has spring tension on it then just trim a bit off the spring, but from the sounds of things it may not be working properly make sure the spring is in the right way and isn't catching on the threads.
are you reffering to what i wrote?
EDIT: Its only logical that when you unscrew it, it runs more boost, pressure is escaping causing the wastegate actuator to stay closed until it creates enough boost to actually open it... same sort of principal as ripping the hose off the wastegate.. except you'll get infinite boost so to speak
so umm... not sure if its the same with this boost controller but a bleed valve is a bleed valve... thats how they work :laugh:
just take it off, open it up, and make sure the ball and spring are not jammed, and seated properly. u can change the spring, or cut it to make it shorter so u get to screw in the bolt a bit more. be careful not to let the ball and spring fly out when u open it up. they do go flying.
thanks for all your input lads, problem solved (not by me tho) CRD adjusted a few things on my car and found out the canister was not connected properly or something like that (didnt understand 100% what he meant) but yeah after adjusting boost controller, fpr, fuel cut defender
hit 204kw at 14psi
im happy and now its running as it should!
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
