This is my first Dyno run in my V35 Sedan with the 6 Speed Getrag fitted, only mod a full Borla Exhaust and K&N filter element from Jash at C-Red
I have been informed the dyno is off so I will have a more accurate one next week, but you can see the torque comes straight on which is mint.
Edited by Guest
https://www.sau.com.au/forums/topic/158845-my-v35s-first-dyno-run-image-posted/
Going to work on the induction system first as I had a pod filter on with no heat shield which was so loud when it came on plus the bottom end was a bit dead and more of a rush at 4,000 rpm, the pod filter only lasted a day, lots of bits in the US and Japan to tune the N/A engine up we will see what it takes to reach 240 hp at the rear wheels.
Jash has some Worx 19's for me then I am going to put some spare RE55's I have on my 17" BBS rims and see how it goes down the qtr.
The torque is so nice and with a different note to it, you could say it is a BMW V8 type sound.
Edited by Guest
Going to work on the induction system first as I had a pod filter on with no heat shield, it was so loud when it came on plus the bottom end was a bit dead, more of a rush at 4,000 rpm so the pod filter lasted a day. Lots of bits in the US and Japan to tune the N/A engine up so we will see what it takes to reach 240 hp at the rear wheels.
The torque is so nice and with a different note to it, you could say it is BMW V8 type sound. Jash has some Worx 19's for me then I am going to put some spare RE55's I have on my 17" BBS rims and see how it goes down the qtr.
Sounds good, keep us posted on it's progress! :(
No offense dude, but according to the Americans I've talked to the Borla is not very impressive at all. Nothing bad said about flow, but more about its quality.
Obviously readings differ between dynos (even in Shootout Mode), but your power figure is what I'd expect from a stock car.
What year is it? Is it running the 280hp engine or the 300hp engine?
You should be able to hit 240rwhp with just bolt-ons. Get the Z33 intake tube (which is less restrictive) or an aftermarket one, plenum spacer (assuming its a 280hp engine) and ECU and you should hit your target. With cats and headers on top of the above I'd expect at least 250rwhp in Shootout Mode.
There's practically zero gains from a pod filter, so don't expect anything but noise if you put another one on.
I am going to use a different dyno and see what it comes up with as Jash did say this dyno is running 20 to 30 hp low it was a "I am bored lets do a dyno run" we wanted to see how the graph looks, the yanks have quoted 220 to 240 rwhp stock. All the other mods you spoke about were done to a CPV35 so we know what is worth while.
Z33 Intake tube works well, plenum spacer isnt worth the hassle, I think ECU is a waste of money, with Cats out and Headers in it is to loud, US headers dont fit RHD cars well and Japanese are not worth the money, a Pod filter on Jash's CPV35 did make a difference.
The quality of the Borla exhaust was faultless compared to a lot of other systems on the market and it is well priced at the same time, it bolted straight up no rubbing, quality fittings but Yanks complain about everything.
A few of us who drive V35's every day all deem it the quickest yet as driving a dozen different ones in a week is a good way to guage any difference.
For real hp I would just get my mates at DNA Motorsport to fit a PROCHARGER and be done with it not waste time and money.
Damn, thts nice..makes me wanna run out and buy one now...u've got the sedan too! Any pics you can share of the car?
I have been meaning to get around to some photos but I was waiting for the 19's I have to be fitted, it is dumped on it's arse but still a bit soft looking with 17's.
They are a lot nicer car to drive then people give them credit and quicker then you think with only a little work.
Edited by Guest
The Yanks don't complain about the JDM catbacks. The Fujitsubo and HKS ones especially come highly lauded.
As for the plenum spacer, its the easiest thing to install! You just unbolt the upper plenum, put this metal spacer on with its gaskets, and then bolt the f**ker back down! And on a 280hp engine, it is worth it. While it only gives you a couple of kilowatts more in the top end, it makes the engine far more willing to breathe and so your usable rev range increases. It also stops your front 2 cylinders from getting starved of oxygen, so it doesn't coke up as badly in there. I'd say they provide a gain at least as good as a pod filter, if not more.
As for headers, you can get a cheaper set locally made. UAS sells 350Z extractors (which will fit a V35) for $600. Cats aren't cheap, though, no matter where you go :(
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
