This is my first Dyno run in my V35 Sedan with the 6 Speed Getrag fitted, only mod a full Borla Exhaust and K&N filter element from Jash at C-Red
I have been informed the dyno is off so I will have a more accurate one next week, but you can see the torque comes straight on which is mint.
Edited by Guest
https://www.sau.com.au/forums/topic/158845-my-v35s-first-dyno-run-image-posted/
Going to work on the induction system first as I had a pod filter on with no heat shield which was so loud when it came on plus the bottom end was a bit dead and more of a rush at 4,000 rpm, the pod filter only lasted a day, lots of bits in the US and Japan to tune the N/A engine up we will see what it takes to reach 240 hp at the rear wheels.
Jash has some Worx 19's for me then I am going to put some spare RE55's I have on my 17" BBS rims and see how it goes down the qtr.
The torque is so nice and with a different note to it, you could say it is a BMW V8 type sound.
Edited by Guest
Going to work on the induction system first as I had a pod filter on with no heat shield, it was so loud when it came on plus the bottom end was a bit dead, more of a rush at 4,000 rpm so the pod filter lasted a day. Lots of bits in the US and Japan to tune the N/A engine up so we will see what it takes to reach 240 hp at the rear wheels.
The torque is so nice and with a different note to it, you could say it is BMW V8 type sound. Jash has some Worx 19's for me then I am going to put some spare RE55's I have on my 17" BBS rims and see how it goes down the qtr.
Sounds good, keep us posted on it's progress! :(
No offense dude, but according to the Americans I've talked to the Borla is not very impressive at all. Nothing bad said about flow, but more about its quality.
Obviously readings differ between dynos (even in Shootout Mode), but your power figure is what I'd expect from a stock car.
What year is it? Is it running the 280hp engine or the 300hp engine?
You should be able to hit 240rwhp with just bolt-ons. Get the Z33 intake tube (which is less restrictive) or an aftermarket one, plenum spacer (assuming its a 280hp engine) and ECU and you should hit your target. With cats and headers on top of the above I'd expect at least 250rwhp in Shootout Mode.
There's practically zero gains from a pod filter, so don't expect anything but noise if you put another one on.
I am going to use a different dyno and see what it comes up with as Jash did say this dyno is running 20 to 30 hp low it was a "I am bored lets do a dyno run" we wanted to see how the graph looks, the yanks have quoted 220 to 240 rwhp stock. All the other mods you spoke about were done to a CPV35 so we know what is worth while.
Z33 Intake tube works well, plenum spacer isnt worth the hassle, I think ECU is a waste of money, with Cats out and Headers in it is to loud, US headers dont fit RHD cars well and Japanese are not worth the money, a Pod filter on Jash's CPV35 did make a difference.
The quality of the Borla exhaust was faultless compared to a lot of other systems on the market and it is well priced at the same time, it bolted straight up no rubbing, quality fittings but Yanks complain about everything.
A few of us who drive V35's every day all deem it the quickest yet as driving a dozen different ones in a week is a good way to guage any difference.
For real hp I would just get my mates at DNA Motorsport to fit a PROCHARGER and be done with it not waste time and money.
Damn, thts nice..makes me wanna run out and buy one now...u've got the sedan too! Any pics you can share of the car?
I have been meaning to get around to some photos but I was waiting for the 19's I have to be fitted, it is dumped on it's arse but still a bit soft looking with 17's.
They are a lot nicer car to drive then people give them credit and quicker then you think with only a little work.
Edited by Guest
The Yanks don't complain about the JDM catbacks. The Fujitsubo and HKS ones especially come highly lauded.
As for the plenum spacer, its the easiest thing to install! You just unbolt the upper plenum, put this metal spacer on with its gaskets, and then bolt the f**ker back down! And on a 280hp engine, it is worth it. While it only gives you a couple of kilowatts more in the top end, it makes the engine far more willing to breathe and so your usable rev range increases. It also stops your front 2 cylinders from getting starved of oxygen, so it doesn't coke up as badly in there. I'd say they provide a gain at least as good as a pod filter, if not more.
As for headers, you can get a cheaper set locally made. UAS sells 350Z extractors (which will fit a V35) for $600. Cats aren't cheap, though, no matter where you go :(
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
