Hi, just brought a 33 and need to do the general maintanence things to it, the powersterring belt is cracking so to replace it do i only undo the bolt on the powersteering to relieve then tension and then just put new belt on and go form there or????
i did try looking and searching the forums but no luck
https://www.sau.com.au/forums/topic/158888-power-steering-belt-replacement/
There is a locking bolt that holds the adjusting bolt in place.
Put a socket through the slots on the powersteering pulley, and the bolt is right there. Once that is loose, you should be able to loosen the timing bolt (The really long one) until you can push the PS pump towards the motor and pop the belt off.
Same thing back on, and then check it in a week or two, cause the new belt will slacken as it wears in/stretches.
Cheers heaps dude
