just wanna know what power output il br running with these mods. what do u guys think?
-pfc
-fmic
-turbo back 3 in exhaust
-pod
-ebc
-slide hiflow (non stage 3)
-tomei fuel pump
-nismo fuel reg
-555cc deatschwerks injectors
-boost set to 14 psi max
-stock afm
-heavy duty clutch
a realistic figure on say 85% duty cycle on injectors.
opinions to mods welcome
(car has only 90,000k's on it)
tuner dosent push them to the limit. protek doing it
Edited by R33GOD
https://www.sau.com.au/forums/topic/158902-how-much-power-u-guys-rekon/
I'd be expecting 230-40 myself. More would be a bonus. Oh, and stock afm? How could you expect more?
i dont really want to change the afm cause i heard its not practical and messes with the idle. plus i cant be bothered spending another 300 on one then i have to pay 400 to get a retune from scratch lol
Oh and get an adjustable FPR that way you dont have to run sooo much duty cycle on the injectors? :D
Hey,
There's no need to worry about the duty cycle of the injectors, as long as you realise you run out of extra flow at 100%.
They do the same amount of opening and closing at 99% duty cycle as at 1% (but the timing is different).
Typically an adjustable FPR is an alternative to replacing 6 injectors where you need 'a bit more' flow (say 15%)
but you don't want to go to the expense of a new set of injectors. Winding up the pressure is the same as installing
slightly-larger injectors, but cheaper (provided your lines can take it ;))
A car tuned for max 85% injector duty with an FPR will go bang just as hard as one tuned for 100% without if an
injector stops working and suddenly 1/6 the fuel flow is cut off. The other injectors, while they have room to flow another
15% each, _won't_ - the ECU won't tell them to...
Regards,
Saliya
Hey,
slightly-larger injectors, but cheaper (provided your lines can take it :D)
Regards,
Saliya
but having the injector upgrade is gonna make it more safe right?
youve confused the crap outta me too by the way lol
Q45 AFM WILL MESS WITH IDLE BUT Z32 DOESNT MAKE ANY DIFFERENCE JUST SELECT Z32 ON YOUR PFC COMMANDER
ITS NOT JUST FLOW THAT MAKES THE Z32 BETTER ITS THE METERS HIGHER FLOW RATEING METRE THAT GIVES YOUR PFC A BETTER SIGNAL.
Edited by r33-d-rift
with the larger injectors there should be no need for a FPR.
the Z32 is identical in size to the standard AFM so it flows no more but the resolution is better with higher airflows, the voltage will be maxed out at or around 220rwkw on the standard unit.
as stated, select Z32 on the menu and tune away.
Hey,
Sorry I wasn't clear.
What does different duty cycle mean? The amount of time the injector is open per unit of time. Have a look at
http://auto.howstuffworks.com/fuel-injection.htm
and the following pages, they call it 'pulse width'.
Does different duty cycle make a difference to an injector? Pretty much not. They're only opening and closing - that's
what they're designed to do. In theory having the magnet on for more time might make it wear out faster - but we can
pretty safely say that doesn't really matter for the purposes of this discussion.
Does different duty cycle make a difference to the burn process? Of course. See the above link.
Are bigger injectors or an adjustable FPR safer? No. They only help if you're running out of fuel - that is, your
current injectors are at 100%.
One set of injectors (working properly) that operates at 100% duty cycle is exactly as safe as a different set operating
at 85%, as long as they are supplying enough fuel for the air. The difference is,
that if you need more fuel with the first set you can't get it - you have to change something (e.g. fuel pressure).
Where you _can_ get a bit of safety margin is by tuning the car up to an airflow level that's say 5-10% higher than
the maximum you expect, then backing the air off a bit (e.g. by turning the boost down slightly). That means that
if you somehow get more air in there (e.g. it's a cold night) the PFC's already been mapped for that higher airflow and
will supply enough fuel to suit.
But that's not a function of injector size or an FPR - that's you anticipating certain conditions and mapping for them.
If your stock injectors can supply enough fuel for this higher airflow, bigger injectors buy you exactly 0 'safety'.
If your car's not tuned for this higher airflow even with bigger injectors, again, no extra safety.
People seem to think that leaving 'headroom' in injectors (e.g. tune up to 85% duty cycle) somehow makes things
safer - it doesn't. Yes, there's room for more fuel flow - but unless the car is mapped for it, it won't be used.
And if an injector goes south the others won't make up the difference...
Regards,
Saliya
Hey,
Regards,
Saliya
thanks saliya u have convinced me to get the z32 afm..damnit!! lol
Im just saying on a side note that the deatchwerks injectors say to try and stay below the 85% threshold im sure, check the flow sheets anyway, as i was aware that it starts going a bit funny. On another side note keep us posted on your cruise load tuning if you have any issues with you set of injectors. Cheers Adam
get a z32 afm and run 18psi. the high flow still isnt a very big turbo so u will still need to run some decent amount of boost to get that power figure up there...
i dont wanna run too high of boost cause i drive like a mad man lol. 1 bar is all i want to go to be safe as im running the stock head gasket
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
