  • Replies 490
Posted Images
Allright, Group buy 10 is rolling, I have 3 confirmed orders:
- Fry_33 for R33 Gts-t front/rear
- dan.1337 for R32 Gts-t front
- djr81 for R32 GTR front/rear
Group buy 10 ending this Friday 25th May - so don't miss out!
Would it cost any more to have them drilled 4 and 5 stud PCD 114.3
Looking at r33 fronts and s14/s15 fronts in both varients.
Price for per pair delivered to perth 6027
Cheers
price please for r33 gtst front and rear, slotted. just want to know when will full payment be needed by so i can pull my finger out and get some new rotors
cheers eli
edit: also need postage to capalaba qld 4157
Edited by ELI
Cheers
YES it will. You will need to purchase one whole crate of 120 pieces of rotors. That cost a lot!
Sorry, no custom drilled allowed.
Cheers
Would i be able to get prices (delivered per pair) for the r33 fronts and s14/s15 fronts in both varients to perth 6027.
Thanks
n i'll just get them drilled 4 stud locally :)
I'm in and paid up for the R33 GTST Rotors F&R
Thanks Rianto
No problems, your payment has cleared...
Will organise all the orders this Friday...
Updated order list:
- k3 for S14 front/rear
Two more orders in tonight:
- SoFly for R32 Gtst front
- fluent for S13 2.0 front.
We have 6 people I will organise to submit this group buy tonight...
Can you also get group buy prices for EBC brake pads?
Looking into R32 gtst grooved/slotted rotors (front) + EBC greenstuff (front & rear)
Possible to get a cheap bundle price for the above setup?
As my pads are worn out and my rotors are undersized :stupid:
Thanks
Patrick
Hi mate, prices for front + rear rotors for the GT-T please. In both slotted and slotted+dimple version please.
I know you said theres no 310mm but would the 296mm for the R33 GTS-T fit the GTT fine?
Thanks,
Andy
Edited by Andi
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
