  • Replies 490
Posted Images
Ok guys, Group Buy 12 is now open, till mid July (15th) to submit the bulk order. However as I've done before, if anytime within a week I can get around 10 people's order I will submit the first batch ASAP so less people are waiting.
I will reply to PMs asap for those who has expressed interests...
Hm, is it just me or this forum is very slow? Took me forever to open my inbox/any messages...
6 orders received as of tonight!
- lwboosted for R32
- jusso for S14
- cheez for R33
- Mazda RX8 rear redstuff EBC pads
- martyf1champs07 for R32 gtr
- dano4127 for R33
Added another 2:
- ak_stylez for R33
- vbevan for Z32
Are the R34 310mm's all sorted now dude? Ive got a pair of stockies sitting here if you need some sent off for copying.
Would you mind PMing me a price on a front pair of 310mms, and a rear pair of S13 discs?
Cheers,
-Luke
Hi Luke,
No I don't need a sample. RDA already in the process of manufacturing 310mm. However will probably be another 2-3 months until the final product is finalised (research, testing, quality control, etc).
10 orders received as of tonight!
- lwboosted for R32
- jusso for S14
- cheez for R33
- dano4127 for R33
- ak_stylez for R33 rotors + EBC pads
- vbevan for Z32
- tom_g for R32
- maximuk for S15
- Godzillr for 2 sets R32GTR rotors
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
