Rda Rotors Group Buy 2007 Is Now Closed!
rs73
 Share
  • Replies 490
Posted Images
Guest carasky
Money sent to your account and recipt sent to you via pm for R33 GTST front Slotted Rotors 1996model, Auto. thanks.
Got a couple more orders in...
- daemon667 for rear grooved & dimpled early R32 GTR
- SLVR32GTR for front slotted early R32 GTR
- hayden49 for full set R33 gtst slotted & EBC red pads
- carasky for R33 gtst front slotted
- wolls for EBC greenstuff pads
Its, woolls ebc redstuff pads Not green :P
Its, woolls ebc redstuff pads Not green ;)
Sorry for the nickname spelling. Correct it's redstuff pads I've got on my order list, just a typo on the forum thread.
Got 6 orders in now...
- woolls for EBC redstuff pads
- scooter_r33 for R33 gtst full slotted set.
whats the difference with redstuff greenstuff which is better for everyday driving with the occasional spirited drive
Hi Mate,
The greenstuff is rated at 600-ish deg C, while the redstuff is rated at around 750deg C.
Have a look at http://www.ebcbrakes.com/greenstuffinfo.html for greenstuff info, and
http://www.ebcbrakes.com/redstuffinfo.html for redstuff info on these pads.
The redstuff is made from the new 3000 series compound.
Some people who has used the redstuff likes them, for the price they gave value for money, and give better feel than the greenstuff. I had greenstuff when I had my R33, low dust, and good daily driving performance. For spirited street drive I'd recommend redstuff based on what people have told me regarding their first hand experiences.
Red should be enough for once in a while club track days (4-5 laps), and hill climb events. But if you're after more racing edge, e.g. for downhill race motorsport, then I can source you some yellow pads or even extreme blue racing pads, but these cost heaps and are R 'Racing' rated compound which RDA told me need to be warmed up a bit before you get optimum performance from it...
So IMHO I won't recommend it for street cars to use anything above redstuff, as they also cost more and probably overkill on most street cars.
Hope that helps...
pm sent..
Update to order: 7 orders in now...
- Linden32 for R32 GTR front slotted (waiting clearance)
All payment for these 7 orders are in:
- woolls for EBC redstuff pads --> upgrade to yellowstuff
For R34 GTT rotors I was told last week they're about 9 weeks away so this week should be about 8 weeks away.
n15m0 & Yo-Yo, if you can send me a pm with "RDA R34 GTT front rotors" in the subject, I will keep it in my inbox so as soon as they become available I can remember who inquired about it.
Updated: 9 orders now
- carasky for R33 gtst front & rear slotted
- P4t for R33 GTS4 AWD non turbo full set & pads
- bangahh for R33 Gtst front slotted (waiting payment clearance)
hey, just for mine you've got me as r33 non turbo its actually r32 gts4 and yes its turbo :P
 Share
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
    • DCS, war thunder, IL2 - mostly flight sim games.
