  • Replies 490
Posted Images
R34NRG, the R34 GTT rotors front are not yet available, there's been a delay with RDA stock... only rear ones available if you want it, otherwise if you want whole set will have to wait...
RDA don't do front disc's for GTT???? I just bought some fronts from DBA and they are great...kinda weird that RDA dont do them... SHAME
They are having them made at the moment, it's probably no one inquiried about them before (until I started the group buy here) so they haven't made any in the past.
I've talked to RDA and it should not be that 6-12 months long to wait, but it's been more than 3 months since they started to look into manufacturing them so if it is available in the next 3 months that would be about 6 months+ in total actually.
For the time being if anyone need ASAP then DBA is the only choice, otherwise go JDM and import something from japan. There's nothing wrong buying DBA, they're good rotors too.
Got a couple of guys misses out so I have taken more orders for a small Group Buy 23 to be submitted ASAP, please pm me if you want in ASAP, probably will submit batch 23 on Monday...
- gtstcoupe for R33 rotors (payment received)
- davieb for R32 rotors (payment clearing ASAP)
hey mate,
good to hear that RDA are plannning to make the rotors for the GTT.
i will be waiting for the rotors for the GTT anyways thanks and keep up the good work!
Edited by lcy
pm replied...
By the way batch 23 was started for those who missed out batch 22.
- gtstcoupe
- davieb
Your orders have been placed and has been shipped...
Will start Batch 24 now...
slotted Front and back for R33 GTS-T postage to 3037
chenx.
I hear slotted + dimpled rotor's are weaker then just slotted is this true?
PM sent...
I think you may have heard talk on cross drilled rotors cracking, but that's not the case with RDA dimpled rotors.
Conventional cross drilled rotors are known prone to cracking under hard use e.g. track/circuit.
that is because a lot of materials are removed from the rotor.
RDA did not cross drilled the rotors but they blind drilled them, therefore the strength can be maintained.
Therefore it is called dimpled, not drilled. So they should be a lot stronger than conventional cross drilled.
But regardless what rotors you have, once you take your rotors to the track, that will void all warranties
of any parts. Regardless what material or whether it's plain or slotted,e t c.
    • For the record, I hate the colour. Even if I'll never see it again, I know its in there.
    • This is another issue I'm fixing. This little valve stops all the oil from draining to the sump when the engine is turned off. What happens eventually is that the engine is a little noisy and has the oil pressure light on for a few seconds after turning it on. Basically it takes a few seconds to build the pressure when all the oil has drained. This valve is a non serviceable part and is attached to the oil filter housing, BMW suggests to replace the entire housing if this valve fails.  As it turns out this valve can be removed and that means you can get an aftermarket replacement, which I did. The failure, for me at least is that the valve doesn't seat properly after a while, which I've demonstrated. The new one is a ball end and always seats properly.
    • Welp don't know if this is good but I can hear a sizzling sound in my battery Hope I didn't fry it. Turns out a bad battery in the multi meter will give a false reading (likely what happened when I said I had 15x volts), swapped the battery and monitoring now. I'm hoping that sizzling sound is just the equlisation charging
    • Yeah I'm happy to talk to whoever, I don't want to take ownership or even manage it if they don't want but I can probably help with hosting on the sau setup. It's a great resource and should be protected.
    • So, got some bits..   New oil filter housing gasket (main problem I'm trying to fix -see leak above)  While you're in there's: New belts, pulley and tensioners.  Vanos oil line New oil drain valve New water pump and pulley  New fumoto valve (all my cars have these). Some of this stuff seems ok now that I've pulled it out but I still have no idea how old it all is.  The belts looked fine and then I noticed this. Like somebody has hooked it with a pick.
