  • Replies 490
Posted Images
My pleasure... I'm starting the next one immediately as there's a few people with urgent brake needs... so if anyone is interested please pm me.
anybody know if it's possible/easy/cheap to get a bracket to allow fitment of a GTR sized rotor (324mm) in place of a GTST rotor (296mm).
its for an R33 if that matters.
d'ya reckon a bracket from a GTR would be a simple bolt on? cos i'm thinking it would be a good upgrade to just buy the GTR rotors from here?
edit:
don't worry, i'm an idiot, obviously the calliper is not going to provide the correct contact surface for a bigger rotor :blink:
anyhoo, can you put me down just for a set of regular slotted's for the front of a R33 (bills suck!)
Edited by made_guy
Hi mate,
This is an illustration of what Grooved rotors look like.
The dimples are not drilled through as to maintain the rotor strength, as too much cross-drilled section in a rotor may reduce it's strength and developing cracks starting from around the drill holes, the dimples also acts as an extra cooling in addition to the grooves - just like a cross drilled rotor.
Hope that helps. I have never put one on my car, but with the Gold Passivated material on the grooved rotors, I would believe that will reduce oxidation that mostly cause those ugly surface rust-look on standard OEM rotors.
Could you please PM costing for front and rear slotted (only slotted) discs for S1 R33 GTST?
If possible please also include costs for all four corners of Greenstuff pads?
Thanks a bunch!
Chasing prices on rotors for front & rear of my S1 R33 GTS-T, frieght is to 4214
FRONTS = Slotted/Grooved & Dimpled
REARS = Slotted/Grooved
Cheers bloke. :)
Also, quick curiosity question.. Are the rotors a simple slip off & slip on job, with just the wheel bearings to freshen up & nip in ?? I had someone tell me that they needed a press to get the bearings on & off - sounds a bit much to me just to fit a pair of rotors. I've changed them on a SII RX-7 and a Gemini, and had no dramas or needed any special tools...
Edited by SHY 33
Guest
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
