  • Replies 490
Posted Images
ok, I'll have to change that, and have to change the part no as well.
do you know if you're using the same rotor as the R32 Gts-t?
i was hoping you would know :) does that mean the price changes also?
I belive the R32 gts4 is same brake as the R32 gtst its only the R33 which has the 4 stud 280mm rotor the R32 should be 280mmFR 297mm Rear
P4t, the price changes, the rotors are cheaper but the pads increases a bit. I'll pm you with refunds due once i've calculated the difference. I just wanna make sure it's 5x114.3mm stud pattern as this GB 15 is closing tomorrow and I don't wanna send an order with the wrong part in it.
Batch 15 is closing now...
- daemon667 for rear grooved & dimpled early R32 GTR
- SLVR32GTR for front slotted early R32 GTR
- hayden49 for full set R33 gtst slotted & EBC red pads
- carasky for R33 gtst front & rear slotted
- woolls for EBC redstuff pads --> upgrade to yellowstuff
- scooter_r33 for R33 gtst full slotted set.
- Linden32 for R32 GTR front slotted
- P4t for R32 GTS4 AWD turbo full set & pads
- bangahh for R33 Gtst front slotted
- frankie60 for R32 GTR early slotted front rear
- madqrk for S14a 200SX slotted front rear
- Michael_1882 - R33 full set (to be confirmed)
- Nismo_S - RDA648S (to be confirmed)
No problems. Theo is that address you gave me your work address? Should I put a company name or just the Level & Street is fine?
Rianto - Although I've replied via PM I'll just reply via here too
If you could just address them to Theo Dinakis and the address I sent you in the PM that would be great. Our mail people here will sort it out and they'll get to me within the hour of them arriving :rofl:
Cheers,
Theo
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
