Update to Group Buy 18 orders: 7 orders received now!
1- Birth for R32 Gtst rear rotors (payment cleared)
2- VSPEC-33 for R33 GTR rotors (payment cleared)
3- 2630GTS for R32 Gtst rear (payment cleared)
4- GTR32GUS for R32 GTR early model full set (payment cleared)
5- Tuan for RX8 redstuff pad (payment to cleared)
6- Simmo195 for R33 Gtst front (waiting for payment to clear)
7- gibbau for R32 Gtst rotors (waiting for payment to clear)
  • Replies 490
Posted Images
Update to Group Buy 18 orders: 8 orders received now!
6- Simmo195 for R33 Gtst front (payment cleared)
7- gibbau for R32 Gtst rotors (payment cleared)
8- r33line for R33 Gtst grooved rotors & pads (payment cleared)
GB 18 submitted.. all according to plan...
From the last time I spoke to RDA it's about 9 weeks from the week of 2nd of August...
So let's see... that would be another 4-5 weeks from now...
Hi, orders submitted so hopefully they will all arrive by mid next week the latest (if you all didn't miss a delivery due to not being home, etc).
Break squeal can also be caused by pads, not only rotors, but things get worse when rotor or pads are badly worn, so see how you go...
Hi
Dont know if this is still going, i jsut read the first post and the last one.
Can you please give me prices via PM on..
1. R32 GTS-t/Z32 300ZXTT: F=909S 280mm RRP $170, R=908S 297mm RRP $190 (Front can be used for S15 Silvias)
3. R33 GTS-t/R34 GT non turbo: F=7693S 296mm RRP $305, R=908S 297mm RRP $190
7. R32 GTS-t/Z32 300ZXTT: F=909G 280mm RRP $305, R=908G 297mm RRP $285 (Front can be used for S15 Silvias)
9. R33 GTS-t/R34 GT non turbo: F=7693G 296mm RRP $465, R=908G 297mm RRP $285
All for the FRONT rotors only please..
Also would it be ok to order blanks or only come predrilled?
Just sussing out which brake setup to use.. thank you.
My current rotors have sort of got circular lines running around them.. they feel bumpy when running my finger up and down. The front break pads are new Lucas's, they were put on during the RWC before I bought the car - so it may well be the pads.
I will be replacing the pads if the problem does not go away after installing the rotors.
Sounds like both rotors and pad problem. If your rotor is healthy, you can have it machined nicely and flat surface.
I had a problem with the old std rotors (93 gtst) which caused steering vibration and squeal, which was fixed by machining the rotors and putting new pads in.
I probably could of got them machined, but figured I may as well just upgrade as I was going to eventually anyway. I'm not getting any vibration (not yet anyway), only squealing.
Why do you say pad problem as well? Brake pads are less than 2 weeks old? Time will tell I guess! I'll invest in some anti-squeal stuff before replacing pads, see how that goes.
I didn't know the condition of pads you have right now... maybe the pad shim is worn out, or when an old pad shim is being reused it may caused all sort of noises, I was told so, as the shim is to ensure pads sits flatly against the rotor and absorb any noises or vibration.
But give your rotors a machining and see how it goes... I had slight groove (not bad) on the rear one and that one was the one I had squeal on, so could be the rotors after all.
I'll check the part number list, if you can confirm that the diameter the same with 350Z front & rear then they should be ok.
Remember that the 350Z has the track version with bigger rotors and brakes (I believe) so this may be the same with V35 Premium coupe with bigger brakes too...
GB19 is going on now, got 1-2 orders so far...
the v35 had a few iterations
the 03-04 coupe had normal spec and a "track" spec which was not related to the premium package. the "track" spec was offered on manual models as an upgrade and included the brembe package. the rest of the entire range had the same normal-spec package
the 05+ coupe no longer offered brembo but had a larger brake setup
so it would be the 03-04 coupe "non-brembo" setup which is what would work
i believe the equivalent in the DBA brand is:
4000 series
front part# DBA 4954 (296mm x 24mm)
rear part# DBA 4574 (292mm x 16mm)
according to the DBA website, the part number is the same for the skyline and 350z standard/touring model 2003-2005
i'm not sure how to find out if its the same with the RDA range so i was hoping you could help :D
Guest
    • H1 is not the Humvee, but is the most road based version. Lachlan (HankScorpio) on here has a proper Humvee. He imported it a few years back.
    • Welcome Thomas! Sounds like you've made some progress. Are you able to drive it and enjoy it a bit now ?
    • HUMVEE are fine in big open areas, but they are problematic on the street and tight areas As for reliability, some of the  US Army guys I have chatted with have said that when they were working they were fine, but, the do spend alot of time in workshops for multiple reasons, admittedly, they did get a hard time by the boys and girls who drove them I would definitely put them in the "buyer beware" category  They do look tough as nails though
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
