Payments cleared through for the following orders:
1. Midnight - for 909G R32 Gtst
2. Holes - for 7693S & 908S R33 set
3. GunMetalR33 - for 7693S R33 Gtst
4. slayer_1971 - for 7701S R32 GTR Vspec Brembo
5. My_Silvia - for 7693S R33 Gtst
6. krizza_ca18det - for 909S rotors
  • Replies 490
Posted Images
Not yet.
The list is building up a bit slower than I expected with only 6 cleared transfers & another 1 or 2 is waiting to clear through, so I will submit the whole thing this Friday. Depending on their stock level they may require 1 or 2 weeks to make the rotors, but in the past it had sometimes been as quick as a couple of days. The delivery itself would probably take a few business days, so it's making/slotting the rotors that takes most of the time.
If there's any delay I will let you guys know ASAP.
Cheers,
Rianto
im still keen on the normal rotors dude..
Will transfer the money in an hour when i get back home..
So you can add me to the list..
If its just normal rotors, will i get it quicker lol.. Coz i really need it asap..
Anyways will pm you now
Sidd.
7. hazerb30 - for 7926G & 908S rotors
8. racsov500 - for 909S rotors
9. siddr20 - for 908 plain rotors
Almost 10 people! Group Buy closing this friday so please order ASAP to avoid any delays.
10. chinkenboi - for 909S rotors
11. OnAhigh - for 909S rotors
Yep, but in the end even if it's less than 10 I will submit it anyhow.
I've just got another one person who might jump in and make it 12 persons.
Will sort it out tonight.
Anyone missing out on this one please hold off and I will advise when the next Group Buy is re-opening again.
We've got everyone's payments cleared through for the following orders:
12. JonesyGTR - for 7926G
Allright guys, I have submitted the bulk order on Friday night, I will advise as soon as I heard confirmation that they are processing the order. Hopefully I should hear something by end of today....
They have confirm receipt of the group order and is processing them right now. Some rotors will start to be delivered from tomorrow onwards, ETA would be either end of the week or sometime next week.
Also, I will be away (to NZ) on Thursday - Sunday so I will only be able to reply to your pm or queries today, until
tomorrow daytime, then after I am back on Monday next week.
Guest
    • Depending on exactly where that voltage is being measured, that is most likely the battery is f**ked. If the multimeter probes are on the battery's own terminals, then it is f**ked. If they are on the car's terminals, then there is a bad connection. Either are fatal to the attempt to start it. Literally just put it on the 20VDC range, put one probe on the battery's -ve terminal (ideally not the car's terminal) and the other on the block somewhere exposed/metal, like an engine mount bolt head. You can also test the earth lead is steps, so from battery to body earth, body earth to engine connection point, engine connection point to some other spot on the engine, to see if you can isolate where a shit connection actually is.
    • I meant to write 50 originally and then double checked the price and found it was ¥12m (125k) and came to edit it and realized I had accidentally added and extra 0 in the first place lol
    • I wonder if the n1 was cheaper when bought new
    • Only reason I started replacing hoses was I went for a short drive to the shop the other day and finished shopping and started the car and started to drive off and could see a big trail of fuel in the rear view mirror. Parked up and found the bottom hose to the fuel filter had busted. Lucky I was near a car part store and was able to get a replacement hose and back on the road. But got me thinking I had owned that car for around 20 years and was all original fuel hoses so probably time to replace all of the fuel hoses. Was pretty lucky it went where it did.
    • A few kg falling from a few feet is enough to move parts of your skull inwards into your brain Also, there's always news about people getting crushed, and occasionally killed, working under cars Be safe is your endeavours
