  • Replies 490
Posted Images
Quotes sent, updated Group Buy 25 orders received:
- WORK32GTR for rear R32 GTR rotors
- CHUNDA for front R32 Gtst rotors
- TURISMO for front R32 Gtst rotors
- bilbo117 for R33 gtst rotors & EBC greenpads
- mlt15e for R33 gtst grooved rotors
- kjb_r33 for R32 gtst rotors
- intouch for R32 gtst rotors (TBC)
i have a 32 gtst and need new disc's, was just wondering if i could buy r33 gtst rotors as an upgrade and not have to change anything else? If so can i get a price on:
x2 front slotted 33gtst rotors and x2 r32 gtst rear slotted rotors?
Ash, if you have a 32 Gtst you will need to get R32 rotors if you do not wish to change anything.
R32 rotors front is 280mm od while R33 is 296mm od, there's 16mm difference there or 8mm bigger on each side.
You need to check your clearance it'll probably hit your caliper or your brake pads position won't be in the optimum location.
The rear R32 & R33 gtst are both the same 297mm od.
If you want then I will suggest 2x front slotted R32 Gtst & 2x R32 gtst rear slotted, unless you want to custom make a caliper adapter to fit the R33 gtst rotors at the front.
Updated Group Buy 25 orders received:
1 WORK32GTR for rear R32 GTR rotors (payment received)
2 CHUNDA for front R32 Gtst rotors (payment received)
3 TURISMO for front R32 Gtst rotors (payment received)
4 bilbo117 for R33 gtst rotors & EBC greenpads (payment received)
5 mlt15e for R33 gtst grooved rotors (payment received)
6 BRUNSKIGTST for R32 gtst rotors (payment received)
7 kjb_r33 for R32 gtst rotors (payment received)
8 AdamD for R33 gtst grooved rotors (payment received)
9 tuitahi for R33 gtst rotors (payment received)
Update: 7 orders confirmed (payment received), just waiting on the other two...
Group Buy Closes tomorrow!
GROUP BUY 25 CLOSED...
Orders to be submitted only those with payment has cleared:
Got mine today, THANKS. Should have actually been yesterday but i wasnt home when TNT called. Have left feedback
Edited by kjb_r33
Hey there.
Keen on Slotted R34 GTT fronts and rears on the next group if in stock.
GT-Passage, R34 front GT-T not yet in stock but I will keep checking with RDA.
It's been a while I'm not 100% why the delay is however I think it's gotta be available anytime this year.
Stolen_S15, I have started group buy 2008 in the group buy section, click the link in my signature...
  • 1 month later...
Guest
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
