hi i am just wondering how much power should i be expecting to get on my 33 gtst with standard turbo,
mods are. boost to 12psi, front mount, full cat back exhause including dump pipe. hks air pod.
and what 0 - 100 times should i be running around??
thanks if any one can help me out.
https://www.sau.com.au/forums/topic/158923-r33-gtst-power/
  • Replies 49
Popular Days
anywhere between 170 to 190 rwkw i suppose, wack it on a dyno and find out 4 sure
https://www.sau.com.au/forums/topic/158923-r33-gtst-power/#findComment-2950179
well skylines did come in auto too.......many of them
Your probably looking around 170-190rwkw as previously stated as i have very similar mods. stock turbo can only take so much, plus it'll be running rich anyways with the stock ecu, aftermarket ecu would probably have a noticeable diference with fuel mixtures etc..
https://www.sau.com.au/forums/topic/158923-r33-gtst-power/#findComment-2950195
haha yeh i know they came in auto to. wat have you got?? manual or auto? so you have very similar mods do you? so wat 0 - 100 times do you get around?? yeh aftermarket ecu will be needed next i was guessing
https://www.sau.com.au/forums/topic/158923-r33-gtst-power/#findComment-2950202
  WogsRus said:
read my sig, but i got 207rwKw at 12 psi and an estimated 217 rwKw at 14 psi
yeh that sounds all rite hey. at how much power should i be thinking of upgrading to a heavy duty clutch.
how much power can standard one handle
https://www.sau.com.au/forums/topic/158923-r33-gtst-power/#findComment-2950237
  NeesaanGTS said:
Yep sounds about right fpr manual 207 @12psi, but 0-100 times you can probably expect 14s or a bit less...you want some good traction!
don't boost past 12psi or rich+retard mode will probably kick in with stock ecu.
yeh dont run past 12. ok then,
thanks .
yeh i was thinking round 14 or less for the quarter.
wat bout 0 - 100 km/h.
https://www.sau.com.au/forums/topic/158923-r33-gtst-power/#findComment-2950252
yeh i will have to head out with the stop watch. i am actually trying to get my hands on a gtek performance meter.
any idea wat power i should be replacing the standard clutch at.
and has any one out there with around the same mods as me run 0 - 100 times?
https://www.sau.com.au/forums/topic/158923-r33-gtst-power/#findComment-2950264
  cliff25gtst said:
yeh you ran a 6.4 using the gtech hey, yeh i am trying to purchase one of those. yeh was that without launching your car?? should easy get under 6 with a good launch then.
That was an off the line launch with crappy traction.
https://www.sau.com.au/forums/topic/158923-r33-gtst-power/#findComment-2950334
