  • Replies 49
Popular Days
may i ask why ur askin about 0-100 times?
what mods are u planning and il give you a little idea on what youd run down the 1/4
hey mate just wanted to no wat times some of you are gettnig.
i have air pod, full cat back exhaust including dump, front mount, running 12 psi of boost. and next am wanting to put in a aftermarket ecu
hey sorry man i aint got msn hey. i am chasing around the 220 mark mate.
will need to upgrade turbo to get that wont i. and clutch and fuel pump and so on
u will need an aftermarket ecu or piggyback, hiflow turbo and bigger fuel pump, stock turbz will probably chit itself at that power level
Edited by R33GOD
yeh i was thinking about getting a new ecu put in. and at that power level i will be needing to replace my clutch to wont i. is there any way that the standard broad minded personch will handle that power? even if its new as?
how uch would high flowing y turbo cost? it will be a bit wont it
wat kind of power van i be expecting if i dont high flow the turbo and i just keep the mods i have and get a new ecu?? and will i have to replace the fuel pump then?
yes u definately will have to change ur clutch. as for a hiflow turbo u can get a sliding performance one for $1040 delivered.
your mods wont stop there lol
should see 200rwk and yes replace the stock fuel pump and buy a safc2. should have a nice little package once u do that
Edited by R33GOD
yeh i van get a high flow turbo for just over a grand hey. that is good as. that means that i wont have to replace the manifold or so will i? when putting a high flow on is there anything else i need to do?? external wastegate or anything?
no u wont need an external wastegate, as for the manifold keep it stock. beats getting picked on by the cops
if u can drive u might be able to crack a 12.9
so high flow turbo and thats all. dont have to change anthing else. sounds great to me.
yeh 12.9s would be great. my dump pipe and front mount go on this week, then i will search for an ecu and fuel pump. would a gtr fuel pump be a good upgrade??
good fuel pump upgrade yes. u dont need a hiflow turbo to crack a high 12
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
