hey guys i got a 32 with a series 1 rb25det in it, i put a 3 inch exaust no dump front mount boosted to 12 pound and have 18inch rims with 255 rubber, do i have a chance of getting into the 13' or is it gonna be in the low 14's. also am i better off using 16inch rims on the rear because of the smaller rolling diametre.
thanks
Edited by yellowsubmarine
thanks
Mid to low 13's if u can get off the line
not sure about rim selection
better with stock 16ns with semis, lighter than mags. what horsepower u running?
no idea i only got car 3 weeks ago and just finished the mods ill prob find out when i go to eastern creek n visit advan 4 a power run
dont worry too much about wheels/tyres yet. just get down there with any and have a few goes at it. sounds like u have a set up to run low 13's, or even 12's, which will take several attepmts to get perfect. personally id go the lighter stockies, i get average of 13.8 off stockies and 13.9-14.0 on my 19" 275. so they aint too much different.
Bring both the 18"s and 16 with you and test both :P
Which rims have better quality tyres?..
are they 18" forged or casted?
i dunno they are from temp so im asuming the stockies will be a better optoin
ah k yeah i was thinking of trying that ill prob be going in 2-3 weeks on wicked wednesday ill put a post on how i went and if the 16 are better
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
