I did mine a couple years ago, just purchase your synchro rings(baulk rings) for all gears or just second, third and fourth if youre on a tight budget (since these are the common gears that go). You will probably be better off doing main bearing and front and rear seals too.
Anyhow parts will probably cost you 300-500 depending on what you get. Then take it to gearbox shop and expect shitloads for labour (they are not easy to pull apart whatsoever). But on the upside, as good as new box for maybe a touch more than the second hand one.
https://www.sau.com.au/forums/topic/158932-5-speed-rebuild/#findComment-2955276
Here's one I destroyed earlier!!!
Got into first, then second but third went BANG, then it sounded like I was draging a tailshaft under the car.
Got a s/h one and it's been good so far.......
Pull it apart in my carport, just need to buy long gear pullers and a ppg gearset or os gikken!
the insides: enjoy
This happened while I was in Bundaberg.
Changed gbox in front yard.
Pulled it apart in Syd.
https://www.sau.com.au/forums/topic/158932-5-speed-rebuild/#findComment-2955799
LOL, I was waiting for someone to bring that up!!
I'll never use that oil again either.
After they put that in it was making a nice bearing whine noise that wasn't there before.
I now use castrol synthetic gear oil and castrol synthetic LSD oil, diff works like new!!!
https://www.sau.com.au/forums/topic/158932-5-speed-rebuild/#findComment-2956732
well i had that decision when my diff went whiny whiny whiny, and i figured its cheaper and keeps my mind at ease KNOWING that your gb has just got all new seals and synchros, and that its gonna hold, and sometimes you might be lucky enough to get warranty. Rather than having a 2nd hand gb which you are unsure about. go the rebuild alot safer
https://www.sau.com.au/forums/topic/158932-5-speed-rebuild/#findComment-2957651
Where do I start!!!
Most are listed in the manual, need alot of drifts supposedly, to put bearings in etc.
spanners
extensions
Socket set
deepsocket set
breaker bar
pin punch set
decent circlip plier set
pitman arm puller
gear puller+ extendable one
Slide hammer to pull out shift rod bearings.(work had one)
rubber mallot
big hammer
A vice to mount the bloody thing on (don't have one yet)!
container and bag to put all the bits in.
clean parts in kerosene.
https://www.sau.com.au/forums/topic/158932-5-speed-rebuild/#findComment-2959240
Pm dan from elite racing . i think his username is 3lit3_32
good bloke to deal with. and wont stuff you around.
my opinion is. if your not confident in doing it yourself. let him do it.
i was about 75% confident in being able to do it. but at the end of the day. i have more confidence in him and his warranty on workmanship :)
https://www.sau.com.au/forums/topic/158932-5-speed-rebuild/#findComment-2961483
a pat on the back to the first person to guess what oil GTRsean was running
i know...do you
Hint: some times called. Smurfs Blood
:ninja:
RellikZephyr
Not to get tooo off topic, but heres a good one of an old house mates gearbox when the smurfs blood tried to escape. Only problem was that it was a straight cut box that had been in for 2 weeks or so.
http://www.clubpoint.net/bluebird/gb/Img_2844.jpg
https://www.sau.com.au/forums/topic/158932-5-speed-rebuild/#findComment-2962250
Nasty!!
Smurfs blood will always look for it's natural environment. It is futile to try and keep it contained in gboxes for too long.
Pitman arm puller is what is used to remove ball joints.
basically two or three adjustable arms with claws on the end and a threaded center bolt with tip.
https://www.sau.com.au/forums/topic/158932-5-speed-rebuild/#findComment-2962366
