5 Speed Rebuild
The stealth of it is sick. Custom tow bar I assume?
These are also true. I do try to separate myself from the rest of society though. I'm starting to get evil DCT scented dreams though.
Yep, correct. The way you are using the putty is incorrect. Its meant to be used to fill those tiny pin holes, its not a body filler substitute. I'd sand back all of that putty and do it again with body filler. -
I was thinking it's helpful in clearing any doubt that everyone needs a bigger turbo and a new aftermarket ECU. Or an engine swap and sequential box...
By dingleberry · Posted
thanks very much for all the replies, huge help. to follow up with @WMDC35 so stick with the de neo loom? would some sort of plug and play ECU designed for the r34/25neo work? looking at maxxecu’s but open to suggestion
