ok so it wasmis firing the other day and i made a thread about it. i changed my spark plugs. now it doesnt want to boost really. like it does sort of i can here the turbo spooling but its very resticted and stuggles to rev over 4000 revs especially in second gear upwards. ANNNNNNd its still mis firing. wtf so its actually worse now because b4 i could rev thru the rev range but not at full throttle now i cant get thru there at all no matter what it just starts mis firing. i checked my coil packs and the seemed all good. brand new plugs. could it be a tuning issue? some on has to of had this problem b4
did it make any difference if you put the old ones back in ? might be a dodge plug or not in properly , but prob be more likely to be coil packs. How old is the car and kms ? but i'd be trying the old plugs in again before you fork out the $600 for new coils
yeah dude its either coil packs or spark plug ive had 3 skylines and i had both probs, with the spark plugs change the spark plug gap from 1.05 to 0.85 or 0.80 car stop mis firing and the other is coil pack its a common prob with skylines on the bottom of the coil pack were the rubber bits conect they sometimes get the smallest crack u can bearly see it what i did instead of forking out 600 bucks for coil packs was got a rubber gasket glue and smeard it all over the bottom half of the coil pack this prevent the spark from going out the crack on to the tapper cover . send me a msg on how u went with that
does it start to miss fire when it hits boost and then goes alright near rev limiter, trust me u can bearly see the crack if its coil packs, the other thing is that it could be shit fuel i bought some fuel in batemans bay and it was a independent shell station i whack some octane booster and then it ran alright.just a questoin did start to run crap after u filled it up and r u using 98 octane fuel
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
