u should search the forums first, as theres mountains of info already here on ecus
powerfc if you can get it
other wise there are a heap of other options
links, haltechs, safc, really depends how much you wanna spend
Edited by Spook's_Skyline
https://www.sau.com.au/forums/topic/159007-ecu/#findComment-2951061
If your not upgrading the Turbo...don't waste your money.
I am sure you are able to re-map your standard ECU.
If you must safc...
yeh wanted new ecu with standard turbo first. and then when get more money will go to a high flowed turbo.
https://www.sau.com.au/forums/topic/159007-ecu/#findComment-2951218
Spend the money only once on the tune...do the turbo and safc / powerfc ,and boost controller all together.
yeh i am just running a manuel boost controller. will that have to chang or will it be ok to keep??
so no need for a ecu on standard turbo hey??
https://www.sau.com.au/forums/topic/159007-ecu/#findComment-2951260
Manual boost is good.....for the turbos.
Aftermarket ecu...don't bother on standard turbo.
Re-tune and map your current ecu...if you want to keep your turbo.
https://www.sau.com.au/forums/topic/159007-ecu/#findComment-2951313
yeh re map and keep standard ecu hey. any good performance shop would be able to do that hey?? i a from victoria
https://www.sau.com.au/forums/topic/159007-ecu/#findComment-2951322
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
