u should search the forums first, as theres mountains of info already here on ecus
powerfc if you can get it
other wise there are a heap of other options
links, haltechs, safc, really depends how much you wanna spend
Edited by Spook's_Skyline
https://www.sau.com.au/forums/topic/159007-ecu/#findComment-2951061
If your not upgrading the Turbo...don't waste your money.
I am sure you are able to re-map your standard ECU.
If you must safc...
yeh wanted new ecu with standard turbo first. and then when get more money will go to a high flowed turbo.
https://www.sau.com.au/forums/topic/159007-ecu/#findComment-2951218
Spend the money only once on the tune...do the turbo and safc / powerfc ,and boost controller all together.
yeh i am just running a manuel boost controller. will that have to chang or will it be ok to keep??
so no need for a ecu on standard turbo hey??
https://www.sau.com.au/forums/topic/159007-ecu/#findComment-2951260
Manual boost is good.....for the turbos.
Aftermarket ecu...don't bother on standard turbo.
Re-tune and map your current ecu...if you want to keep your turbo.
https://www.sau.com.au/forums/topic/159007-ecu/#findComment-2951313
yeh re map and keep standard ecu hey. any good performance shop would be able to do that hey?? i a from victoria
https://www.sau.com.au/forums/topic/159007-ecu/#findComment-2951322
