OK Guys ive got a brand new Garrett GT3576 with following specs
Internal gate
.65 front
1.16 rear
Ball bearing
As stated will accept anything over $1000 highest offer
Nik
0424541611
Edited by mrhele
  • Replies 41
hay buddy i have a mate who needs a new turbo for his 200sx. do u know how this would go on an sr20 and what would be needed to fit it
regards
pics would be great as well
julz
yer 3571 are the older series this is a brand spanker, i think gcg sell them for around 6-7k
its a T4 flange and not sure of power
It should be ok for a 200 but will spool up late like 3.5 on a sr apparently they are good for anything over 2.5l
Your mate would need a flange adaptor and new oil and water lines
sorry champ ii forgot to add my number ( my memory isnt the greatest) 0424541611
Pics ill have 2 do tomorow night after work got charge up the camera, no idea what the power rating is for it and i bought it cause i am tossing up between either a VL or Skyline as my next project
[quote
do u know the power rating???
Garrett website states that the 3571 was a journal bearing turbo, with similar housing set up and suitable for engines making upto 390HP. I would guess this 3576 is prob maybe around 450HP with the ball bearing. just a guess though. Seller would have to confirm this though
Edited by Spooner
Tell me more and show me pics , have seen GT3576 bush bearing turbos and occasionally pedal a truck with one fitted (Late FTS Isuzu with Si Tech donk) . Never ever seen one of these in a ball bearing cartridge option .
Yeah I'm interested - if its ball bearing . PM me .
Cheers Adrian .
mate just going by a chart i had at work! In all fairness i said my fault if i was missleading in anyway. If you got something positive to say, say it other wise F U C K OFF
Edited by mrhele
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
