hi guys i have a s2 r33 gtst and i amwondering wat to do next.
ok so far i have standard turbo still. i have a hks airpod, bov. boost controller running 12 psi,
full cat back exhaust and i am putting on a dump pipe and front mount intercooler next week.
at the moment i am just keeping the standard turbo. is there aything else i need to do with these sorts of mods?? eg, fuel cut defender? upgrade fuel pummp?
whats next?? please help?
https://www.sau.com.au/forums/topic/159051-r33-gtst-wat-next/
how much power you chasing id go for the smarts things liek a power fc plug in n play easy also a walbro fuel pump and maybe some injectors and if you wanna do a turbo as i think you do try one of these
KKR430
http://www.otomoto.com.au/kkrturbo.htm
all pretty resiable priced wont cost you a arm and a leg but still get awsome results
it depends on wat your chaing big power or nice n reliable all round 240rwkw
KKR430
if i add the kkr do i need to replace the manifold or will the standard be rite?? and do i need a external wastegate? or would an easier choice be to high flow the turbo
direct replacement nothing required
yeh so it is a direct replacement hey. sounds good hey. not to expensive either. pretty cheap/
are they of good quality. tough??
so no external wastegate needed ??
wat else would i need to do? if i got the kkr i would need upgrade fuel pump, ecu? and injctors.
is that all>?>
is that all>?>
these turbos are on the ls1 tt kits have a look on the bottom of that page good quality turobs no waste gate needed internal gated
KKR turbos are not direct replacement.
If your not looking for huge power get one of the slide highflows, not much better "bang for your buck". (Search for slide) And alot more stealth, which is always important in good old victoria.
But like Paul said before you do anything get fuel pump and tune.
KKR380
The ultimate turbo for SR20 or large twin-turbo applications
Water-cooled, 0.86 turbine housing, suits T25 size flange
Internal wastegate with 8psi actuator
Suitable for single-turbo applications on 2.0-2.5 litre engines, or in
twin turbo kits on 4.0 to 6.0 litre engines
Comes with exhaust flange featuring 3-bolt outlet, T25 exhaust gasket,
oil inlet banjo bolt and oil return gasket.
thats the one id go for with a power fc n pump since you have the rest
yeh had a look. yeh so 840 bucks later and this could be on my skyline hey. good power output from it i am guessing. i was chasing around the 230 mark.
i am happy with this turbo. it sounds the way to go. wont need to change dump pipe will i??
id be guessing so ring him ask him he is pretty good to talk to but like i said dont go getting a turbo n say yer awsome invest in a ecu power fc is the best option with a fuel pump you looking at aorund 1200 for both even cheaper if you look around then get the turbo
yeh my pipe and intercooler are on this week and then i will be saving my pennys and looking to get my hands on a new fuel pump and ecu. and yeh either this option or high flowed option sounds good
Also if you dont have one yet get an upgraded clutch and flywheel combo, also some good brake pads and fluid. All the power in the world is useless if you cant slow it down.
yeh i gathered about the clutch giving way.
thanks for your help guys. will be looking forward to getting it done down the track. would be interested to see how much power i have now at the wheels
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
