Item: Nissan Skyline R34 4DOOR GTT 1998 (SEDAN)
-silver
-82xxxkms
-major sevice done when car was imported 3 yrs back. timing belts etc changed @55xxxkms
-brand new 20% tinted windows (2 weeks old)
-full nismo kit
-k-office castor rods
-brand new split 1 piece dump pipe
-brand new straight through cat back with twin polished 3" outlet
-brand new G4 coilovers (drift spec) 12kg front 9.8kg rear
-brand new kls fmic kit with polished piping
-K-office castor rods
-brand new pod filter
-impul starcorp racing wheels 18x8.5 (front 235/40/18) 18x9.5 (rear 265/35/18) falken ziex tyres
-full service done less than 300kms ago (incl: motul 8100 oil, oil filter, fuel filter, spark plugs, coilpacks)
-kenwood mp3 colour headunit cost ($800) 2x pioneer 12" subs 1x pioneer 1000w monoblock amp
-8000k HID XENON light kit (after market)
-HAS 5 MONTHS REGO. CURRENTLY HAS RWC
Item Condition: interior and interior in imaculate condition, no scratches no dints perfect paint!
Reason for Selling: dont know
Price and Payment Conditions: $25000
Pictures: yes
Contact Details: 0430168117
Edited by drf34
is this car located in darra? i think your neighbour is my girlfriends nuna. hahaha.
this car is immaculate in person. very beautiful car. good luck with sale. id buy it if i had the cash and could sell my 180 in time. trade? haha
yeh this car is in darra.. thanks for the comments. bump!
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
