SK, I get your point about having a progressive throttle response, which makes complete sense when you think about it. Kind of makes me wonder why I didn't put more thought into it before :)
Question is now, what do you do to get a more progressive throttle response?
I guess it mainly comes down to the turbo and tuning. I'm guessing its better to go on the smaller side for turbine housings?
Nice footage Roy, I've watched it about 10 times now :P
Go the 26/30 :ninja:
Actually for th etime being i think better supension and brakes will make my car quicker then more power. So may have to start selling off the engine parts to pay for the suspension/brake upgrades. RB20 can provide enough power for the lighter R32 GTSt to punch with 300-330awkw GTRs
  • 4 months later...
Thought i might bump this up for those that are interested in a cheap R32 GTSt Club Car.
I have now shelved the idea of running a bigger displacement motor and more power. I have recently spent a small fortune (not to some owners but was to me) on new suspension and brakes, Suspension was a huge success, i hope the new Brembos firm up brake feel then the car will be all sorted in the suspension and brake department.
For the time being with the new suspension and brakes im reasonably confident the car can lap within 2 seconds of the real quick GTRs. its so much easier to drive a slow car fast then a fast car fast....and with only 230-250odd rwkws the car feels underpowered now, so very easy to drive.
So if your planning on a club car then stick with the RB20. It is now tempted to strip all the weight i can out of the car as i now have a half cage (added weight...SHIT!!!) and an RB25 gearbox is about to go in (arghhh more weight again)
For the time being i dont see the 15k on engine and turbo is going to make the car that much faster, sure faster but not 15k faster...and the fear of a plug killing a motor etc
  • 3 weeks later...
The 324mm upgrade using the std caliper is a great value upgrade and had been working well. I decided to upgrade as its been 5 years since the last tidy up of the braking system. So thought i would throw some new braided lines, master cylinder and perhaps even brake booster (depends on $$$). While i was at it i thought i would upgrade to a nicer caliper and rotor setup in anticipation of the car carrying a little more weight and more hp.
Also i dont have ABS and i hope that with the more rigid caliper and larger rotor that i can have more confidence in teh middle pedal and hopefully lock brakes less.
But testament to the old setup is that its still on the car and i have had the brembos layign around for over a month now. It works well and im in no real hurry to swap them off the car and find teh Brembos make no difference >_< ... :(
I am now running re-valved Tein RAs with what i think are custom springs. Though i havent really looked under the car to see if it is still using the 10k and 8k springs that they came wiith, I think they are, but need to check. Car rides great with the way harder springs.
Uinique Autosports (02) 9620 9000
thanks for the reply roy,
i have the full sk package and am very happy with how it behaves on the street during "spirited driving" just thought id ask what uve gone to as my pos is just about ready for the track and i think once i get out there i will be looking for something harder. Wether i get SK to rebuild what ive got a bit harder or go a jap route like u with revalving and custom springs i dont know.
I also plan to have a cage long term so that will allow the use of slightly softer suspension as SK has said ( ithink :))
thanks for UAS number, they dont have it on there website, and with a a garage in the family i know why :D
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
