I am selling a GTR, looking for a quick sale.
R32 GTR 1990,
Rare Black,
Tinted windows,
Low k's,
Blitz 17 inch wheels,
Tien adj coilovers,
Greddy turbo timer,
Aftermarket s-wheel,
Hks cam gears,
Tomie Poncams, 3000k's old,
Nismo 660cc injectors,
Apexi power FC,
RB25 AFM's,
Greddy profec b boost control,
4 inch trust intercooler,
Nismo fuel pump,
Brand new extreme cussion button clutch, done 3000k's,
Trust high mount manifold and 50mm wastegate,
Brand new garret 600hp gt35 turbo, done 3000k's,
Full 4 inch exhaust, HKS Drag series CAT Back,
Twin Apexi pod filters,
Alloy radiator,
25 row oil cooler,
Radiator deflector shield,
MP3 Stereo, all speakers upgraded with front splits,
Nismo Adj Fuel Pressure reg,
Reco'd and tightened rear diff,
Hicas lockbar with all hicas components removed,
Alloy subframe bushes,
Carbon fibre bonnet,
Ganador mirrors,
PIAA Headlight booster,
Alloy gearknob,
Nismo 320k speedo,
Reg till Aug,
etc etc.
Car has made 350kwatw on 20psi.
Mechanically in excellent condition.
Looking for quick sale, owner going overseas.
Asking $24000 ono.
Call 0410697349 or email [email protected] for any info.
https://www.sau.com.au/forums/topic/159094-r32-gtr-black-350kwatw-many-extras/
  • 4 weeks later...
Hey man,
VERY INTERESTED!
Please send location and pics to me as well as kms travelled!
Thanks and i await your response
Here are some pics.
Please note the rims,front brakes and rollcage are not included in the price. The full listing of what is included is above.
Car has 10,000k's on the clock, but the dash has been changed.
cheers
how much 4 car as in pic u got pics with the wheels that are advertised
Brakes cost $4500 and are basically brand new and the rims cost $3300 from japan and have been on the car for less than 500k's so i was going to sell separate to reclaim the money.
I will pm you with a price and post pics of the other wheels tomorrow.
cheers
  • 1 month later...
350 kws at the wheels.. internal work for sure.. i dont think a stock block will handle that power... i like ur bonnet were did you get it from ??
i had 487kw @ all 4 wheels and it was a stock crank and stock block!!!!!!
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
