  • Replies 665
Charlie Murphy "Ill challenge you to a duel!!"
Charlie Murphy "Someone had to go!!"
anyone
i aint driving ill be there for party support :D
Join the club Paul.. im with you there :nyaanyaa:
VIC FTL! :(
You said it Bec!! :P
You cant get sick Corinne......Sickness is not aloud!!!!
Only if your fully sick!! :domokun:
Do you guys know what time you may get in to Shep (DECA) ?
And are you all staying at the cabins with us Vic people..?
Should be getting there early evening cause will be heading off fairly early in the morning :D
We are all staying in the cabins just not sure if we will be next to one another
Steve,
Ive forgotten to fax the entry details off - I know I know Im slack!!!
I'll get it done tomorrow as Ive left my CAMS licence at home.
Ok,
so who is in whose cabins?
And we need a "garage/pit stop/workshop" for a bit friday so we can change our tyres etc and get the cars ready on the fri night, with beers of course!
Steve,
Ok,
I am sleeping in the big bed with Andrew and Jess :)
Haha Its called the side of the road :D
Arrival for Shep is approx 6pm
Yep ive sorted cabins - then just grab a bed, its easier that way
Paul - i will get very drunk again, but keep that chick with the mace away from me this time
Chris - tsssk tsssk :)
you can probably bunk in my cabin if need be dif, i think there is a spare bed there. as long as you don't snore. lol.
Haha nice.. Hell no.. I have a tendency to try and smother people with pillow who do snore.. :\
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
