  • Replies 665
Hi Bec!! :dry::pwned:
and ill have my licence back by then
Me too :(
we will enter smoky into the ladies category
Sounds like a plan Paul!!.. Does that mean I get to used the ladies toilet too?? :( I might actually have half a chance of winning!! :(
nooooooooooooooo, i wanna win one!!!
that's another girl i'll have to sabotage :(
Hahahaha!! dont worry Sarah.. ill be giving you dirtys to put you off :(
Me too :(
LOL :laughing-smiley-014:
What a GREAT SUCCESS
Wow congrats Tim, You did really well for your first time..
I got a little coaching on the wangs that helped - mmmm who was my co-pilot?
Except for that bit in Albury on the way up :)
Now remember also - if you guys come a day earlier next time Winton which is right near Shepparton (you remember Benalla about 30mins down the road) is open for practise most Fridays and you'll all already have a license for it if you did DECA on the weekend (aka CAMS or AASA is needed). And as far as tracks go it is most like Wakefield in that it isn't high speeds and is safe and fun to drive.
The Winton thing sound great. I'm good to go up a day early and spend the day there.
Now do we get to call ourselves something stupid like 'Team Wang'? LOL!
I think we should come up with something.
Can you tell me what happens if the Track is wet and same as Skid pan? Both events still go ahead?
Only time we stop is if there is lightning. Then it's a bit scary on the skidpan.
Otherwise it's all steam ahead. Although the skidpan is near impossible when it's wet.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
