I am getting a new clutch put in and a lot of people have said.. Why you are at it you may aswell machine the flywheel, get a lightend flywheel...
What does a lightened flywheel do... Im told increases acceleration....
My dad wants to know.. and I need a reason that will make him think it is a good idea to get... He thinks its fast enough as it is...
Also if i were to get it done, what would i tell the mechanic to do... do they just drill holes in the current one to make it lighter?
It would be good to have an answer by 10:00 tomorrow.. thats when im taking it in...
Thanks,
https://www.sau.com.au/forums/topic/15913-upgrading-flywheel/
  • Replies 54
It's best to get an aftermarket one rather than go down the route of lightening the standard one. I guess theres an inherent risk when lightening and machining that some structural integrity may be lost and possible inconsistencies could lead to failure.
And flywheel failure is not a pretty sight or so im told.
Red17
Ok the idear of having a lightend flywheel is that it will have a considerable loss of rotating mass which in turn makes the car rev’ easier and decelerate quicker into corners.
Its best to get a Billet Steel Lightened Flywheel, that has the strength as well as being lighter. Because Flywheels do let go! so stay away from the Aluminium ones. Stick with steel youl be safer and still have the performance advantage.
An aftermarket steel flywheel will be more like $600, but it is a worthwhile improvement.
Whatever you do do not try to lighten the stock flywheel, you cannot remove enough material to make any difference without seriously weakening the thing. Also you will need to balance it afterwards.
Either get a new steel one, or leave it stock.
Originally posted by dru32
ok then.. where could i get an aftermarket one from... I have $150 for it... That would be enough wouldnt it...
Is there a particular size i should ask for??
What brand ect would be best??
So you say steel would be better/safer than alloy?
Thanks,
$150 will be lucky to get you a stock steel flywheel! :(
www.horsepowerinabox.com have one, its $395 bucks made for RB25DET, thats just the flywheel. its located here:
http://www.horsepowerinabox.com/mall/fw03.asp
probly next wednesday? (Pay day! :P )
And no i dont get $10K a day like your slack sparky ass! :)
Because this guy might get one soon, i spoke to the guy who runs the site. I have been incontact with him about getting a clutch as well.
These a really good quality flywheels, good cheap performance mod!
Guest INASNT
since when do i get 10k a day? it takes me 2 months before i make 10k! (before tax ofcourse)
I get paid tomorrow and waiting for another cheque to clear for travel expenses.
Yes get discounted price plus shipping cost to mel, and check that it will bolt onto the new clutch u got
I am at college at the moment so I am unable to send any email.. They Wont allow access to hotmail... I will get back to you tonight...
How long do you think it will take to ship here.. Ive never done anything like this...
Does it get posted to my door... Do i pick it up from a local Post office?
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
