I'm only looking for one reversing light switch.
I will see what i can do,as i will ba doing a manual conversion down the track...
maybe a R31 or 240k switch will fit??
I do know of one spare switch, i will ask its owner if it will be available
  • 4 weeks later...
  • 1 month later...
this might sound weird but i just need the heater control knobs. Ive lost a couple and need to put some back on.
:laughing-smiley-014:
how $70 sound? i mean i will keep them aside for you... ( 4 wen you pic up the power steering stuff)
Ta muchly.
just another quick question.. with the power steering stuff, will i be getting the steering box, pump, bracket and hoses??
Like the full kit?
yeah mate, my Blue MR30 is in really good running order, and if it does give way one day i'll just buy another car for parts!
the whole setup is still there, all bolted up... i havent checked it for leaks etc, but i did drive it 200km and there werent any problems then!
theres also a few pipes that run across the front of the aircon condensor, i guess thats to cool the PS fluid.
I dont have air con. Is this gonna be a problem? Or will just be able to bpass it?
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
    • Does anyone find that they have to tighten their alternator belt once in a while? Mine started squealing again.
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
