Yeah gets boring quickly. I have 270rwkw and am trying to resist the temptation to go for 300+.
haha 300+ still gets boring...but then you have to start looking at powering a couple of extra wheels to enjoy it more...i.e. GTR :whistling:
  • Replies 51
im sitting on that figure...only few months and i want more already
just cant get enough...300+ all the way!
Back to the topic, u'd feel the difference (more as a passenger), but it wont be scarey tbh..
300rwkw in our gtst has a similiar power to weight as a gtr/gts4 pushing 340-350rwkw. :S
you're shitting me? Here I was, thinkin about buying a GTR and running 320awkw
hhmmm......
why so? The extra weight?
Weight it is....
Mafia.. If you want to improve acceleration and remove some lag drop a set of 4.3 diff gears in your r33. Its a noticable improvement over the 4.11 and 4.08's. I've recently went from 4.08 back to 4.3's as I was bitterly dissapointed. All though first gear was a little more usable second+ sucked in comparison.
I 'assumed' the slightly longer gearing would provide a little more load for the turbo resulting in earlier boost and mask the longer gearing. Definitely not so infact nothing of the like. :yes:
The longer gearing made the car feel laggy as it spent more time in the off boost rev range trying to accelerate in to the 'boost zone' lol :)
4.3's FTW. Definitely recommended.
Those with gtr's look at a set of gts4 4.375:1 diff ratio, the r32 gts4 gearbox also runs slightly shorter ratio's in the first couple of gears and by model/part number the same gtr gearbox just different ratio = same strength.
Quite freaked out how much the lower ratio reduces the lag feel.
Weight it is....
lol read what you posted - its confusing as hell!
So the 4.3's will make it less laggier?
What sort of cost is involved? Will it be just as strong?
An R200 is an R200. Plenty strong apart from the open wheeling vlsd's once you start to push some decent power through them.
Crown and pinion from an r32 gtst diff, have it setup with your housing and center for ~$200.
Regarding cars that are quick...... The only car that has made me think wow... was cruising along side Jays 450rwkw Cressida. It sounds awesome and looks the business as it accelerates off. Under 400-350rwkw just doesn't seem to look like its going all that quick. :)
I can't comment on darrens 470rwkw rb30 as I haven't seen it in action. :yes:
