Nope, its the first one he's seen to do it. I have used this dyno since day 1 when my car was completely stock it dyno'd at 97kw@wheels and the boost did the exact opposite it jumped at that same point. We then put an exhaust on and dyno'd it again, same results with the boost but power jumped to 115kw@wheels. I then had the ebc and fmic installed and we dyno'd it again and got the opposite, boost was now dropping at the same point instead of holding firm and power went up to 235hp@wheels. So I got the dump+front pipe done and power went up to 245hp@wheels but still having the boost issue.
Yes they do, I'm running very very rich at the top end, which is due to the stock ecu. I will be putting in an aftermarket ecu to sort that out, but that may fix the boost problem, looks like a boost cut. Dunno if I will bother replacing the actuator with a HKS as I'll probably be changing the turbo.
My bet is that the dyno operator T'd his boost gauge into the wastegate line. So when either the factory boost solenoid opens up, the pressure in the WASTEGATE line drops closing the wastegate slightly, increasing boost at the MANIFOLD.
A 3psi drop would have shown up as a big change in the power curve :P
The drop is to sudden and then it holds the boost to flat (approx 1psi) to be a wastegate spring I would think.
I would be checking out the EBC.
Seems almost like you still have the standard boost solanoid plugged in but some how backwards.?!?!
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
