mine is an aftermarket double din unit from hong kong has worked well and had no probs has input for reverse cam and input for gps a verry good setup for 450 ebay sells sim units
is it a 'Eonon' unit?
If no, what brand is it?
  • Replies 98
Here is a pic of the standard air con wiring plug for the Stagea, couldnt find a pic of the NAVI unit one, and dont feel like pulling mine out tonight, so compare the plugs. Might also need to consider the surround and brackets.
youll just have to compare the plug with the back of your Navi unit, you would think they would not make different wiring harnesses but rather adapt the unit, so my guess is it would work..
do u know anywhere i might get a non-navi climate control from??
plenty for sale on yahoo auctions japan, through http://www.slidewizeimports.com , select stagea c34 + air con
eg http://page19.auctions.yahoo.co.jp/jp/auction/x18711156
Edited by chook
NTSC, 12v reversing camera - actually flips the image so it is just like looking in a rear vision mirror.
Ebay is a good start but it you are looking for "better" quality, then car audio stores or even J-car, but I think the J-car ones look very similar to the Ebay models...
  • 3 weeks later...
this is my unit but heaps better now for round same dollars
what did u do with ur climate control??
if finally found a pic of what i want to do. i seen this in another stagea when i was looking at mine. the plan is to remove the navi unit and replace it with this
Edited by Raysboostin
  • 1 month later...
... another option with switching on/off camera etc...
In my pathfinder I installed a cemera in the tailgate for hooking up the trailer and parking etc...
I originally was going to do the switchon with reverse etc but I had a novel idea and ran another camera to the top of my trailer canopy (has a nose canopy the first 3rd of the trailer)... this allows me to reverse my trailer at night (night vsion camera) with no help at all but also is a rear view driving down the highway... so turning the camera on/off became redundant.
I didn't have a switch box for the AV I just unplugged and pluggen in the one I wanted.
I just switched from screen to screen camera or watching DVD etc.
If I remove the Tape/Radio player from my Nav/TV/Climate and CD/Radio combo setup and relpace it with a decent CD/Radio will the Nav/TV/Climate Control will still work normally?
ant
Edited by ant0ny
I've been looking at the exact same ones mate!
They look heaps good for the price you pay. :teehee:
Have you had any problems with it at all? CD's not reading, etc?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
